1 Reply Latest reply on Oct 24, 2013 4:19 AM by Simon Turner
    InsertDwgOrDxffile2 not inserting dxf into Drawing sheet.
    Lyndon Crossman
      I have written an addin using VB.Net and the inserting of a dxf file works sometimes while doesn't other times.
      Here is the code I am using based on examples found online.Any suggestions why it isn't working?
            'Clean DXf for Laser Filter.
              CleanDXF(sDwgFileName)
              Dim dxfExtents() As Double
              dxfExtents = getExtentsofDXF(sDwgFileName)
              Dim Xscale As Double
              Dim Yscale As Double
              Xscale = dxfExtents(0) / 9
              Yscale = dxfExtents(1) / 6
              swModelDocExt.InsertObjectFromFile(sDwgFileName, False, 4, 10.0 * 0.0254#, 2.3 * 0.0254#, 0)
              importData = swApp.GetImportFileData(sDwgFileName)
              'Unit
              importData.LengthUnit("") = swLengthUnit_e.swINCHES
              'Paper size
              bRet = importData.SetPaperSize("", swDwgPaperSizes_e.swDwgPapersUserDefined, 8.5#, 11.0#)
              'Position
              bRet = importData.SetPosition("", swDwgImportEntitiesPositioning_e.swDwgEntitiesSpecifyPosition, 0, 0)
              'Import method
              importData.ImportMethod("") = swImportDxfDwg_ImportMethod_e.swImportDxfDwg_ImportToExistingDrawing
              If Xscale > Yscale Then
                  bRet = importData.SetSheetScale("", 1.0, Xscale)
              Else
                  bRet = importData.SetSheetScale("", 1.0, Yscale)
              'Import file with importData
              swFeat = swFeatMgr.InsertDwgOrDxfFile2(sDwgFileName, importData)
              If swFeat Is Nothing Then
                  MsgBox(sDwgFileName + " geometetry was not imported into a new view.")
                  Exit Sub
