9 Replies Latest reply on Nov 5, 2013 7:22 AM by Mubashir Tahir
    Cannot open Macros
    Mubashir Tahir
      Hello everyone.
      Hope someone of you experts can help me.
      I have written a macro to write the customproperties of every part in assembly in Excel sheet. It is a very long macros.
      I invest a lot of time. Because I am not an expert in writing macros.
      When I oppen it today to edit the macro, it crash. I can not open it.
      Can anyone of you open the macro and safe the code.
        • Re: Cannot open Macros
          Keith Rice
          Welcome to the forums.
          Many times it's not enough to just re-save the code on someone else's computer. They actually need to export the individual modules, then you can reimport them into a new macro on your computer. I've attached the exported modules.
          Keith
          SolidWorks API Tutorials
              Mubashir Tahir
              Hello Keith
              Thank You verry much. It works.
              You save me a lot of time.
                Deepak Gupta
                Keith out of curiosity I want to know if you opened/extracted the module via SolidWorks or some other software. If I try to open the original macro posted, I get the same error as Mubashir. Even same thing happens with me on some of my other macros. Any pointer/suggestions to retrieve the macros will be appreciated.
                  Mubashir Tahir
                  Hello Keith and all other helper
                  I have again the same error and I can not oppen the macro.
                  I can not understand how this can happen? Can you unpack the macro and send it back to me.
                  And can you tell me how you do that. It will be verry much appreciated.
                      Laszlo Szucs
                      Hi Mubashir,
                      I could open your code in SW 2014. Here it is:
                      Option Explicit
                          Dim lastRow             As Long
                          Dim lastColumn          As Long
                          Dim FileCSV             As String
                      Public Sub PlexUploadList2()
                          xlSheet.Cells(1, 1) = "Tool No"
                          xlSheet.Cells(1, 2) = "Attribute"
                          xlSheet.Cells(1, 3) = "Attribute Value"
                          xlSheet.Cells(1, 4) = "Unit"
                          For n = 0 To PartNumber - 1
                             If Plex_Data(n).Part_Plexus = "Yes" Then
                                 xlSheet.Cells(2 + n, 1) = ASM_Tool_No + "." + Plex_Data(n).Part_DetailNumber
                                 xlSheet.Cells(2 + n, 2) = "HRC"
                                 xlSheet.Cells(2 + n, 3) = Plex_Data(n).Part_HRC
                          Next n
                          lastRow = xlSheet.UsedRange.SpecialCells(xlCellTypeLastCell).Row
                          lastColumn = 4 'xlSheet.Cells(lastRow, 256).End(xlToLeft).Column
                          With xlSheet.Sort
                              .SortFields.Clear
                              .SortFields.Add Key:=xlSheet.Range(xlSheet.Cells(2, 1), xlSheet.Cells(lastRow, 1)), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
                              .SetRange xlSheet.Range("A1", xlSheet.Cells(lastRow, lastColumn))
                              .Header = xlYes
                              .MatchCase = False
                              .Orientation = xlTopToBottom
                              .SortMethod = xlPinYin
                              .Apply
                          End With
                          FileCSV = MyPath + "\" + ASM_Tool_No + " Tool Attribute" + ".csv"
                              On Error GoTo SafeError_1
                                  If UserForm1.CheckBox6 = False Then xlBook.SaveAs FileCSV, FileFormat:=xlCSV, CreateBackup:=False
                              On Error GoTo 0
                      SafeError_1:
                              If Err.Number = 1004 Then
                                  On Error GoTo 0
