i have an question,,,
some time when i make sheet metal part into drawing format flate pattern wil be like unfattend part,,, why it is so...?
It may be because of two reasons:
The View is referring to unflattened configuration
OR
Flat pattern feature is suppressed in the flat patterned configurations.
As stated earlier, the flat pattern feature is suppressed in the flat pattern configuration. Unsuppress that and you should be fine.
Check attached video for details on fixing it.
i try above way,,, but when i unsuppress and save above part again its getting suppress. in drawing i am not getting flatten view...
Make sure you're not opening the read only file.
The option works fine for me. Check the attached part.
Chetan, please under that in sheet metal there are two configurations; one is for bended part and second is flattened part. In the drawing make sure drawing flat pattern view is referring to flattened configurations.
Can you post a video of what you see on your screen OR how are you inserting the views in drawings for flat pattern.
You can use free and simple to use, video capturing software from CamStudio.
When you do a sheet metal part it has two configurations. One for formed and one for flatten. I went to the configurations and made sure that when I was in the flat pattern configuration that form configuration was suppressed. Then I actived the form configuration and made sure the flat pattern configuration was suppressed. I am glad it works for you.
