I'm trying to finish up a banjo assembly but I continue to hit a wall when it comes to drawing the strings inside the assembly. I created a part in place and want to use the sketches from other parts for my keypoint curve and then sweep. I drew circle sketches in all the necessary parts to give the eventual curve its shape and reference points. When I'm editing the new string part, I can't select the sketches using keypoint curve. I've seen this done before but I can't remember the step for activating? or copying the sketches into the new part.
Any help would be greatly appreciated. I've spent days trying to figure this out.
Can you post pictures of what you have? If you can post your solid models that would be even better.
That way we can see what you are doing and offer advice.
Cheers,
Anna
