JFJacob Frame22/10/2013
Hello everyone,
I have looked at the discussions and the knowledge base but have not found an answer.
I am currently running SW 2014 from a fresh install of both Windows 7 and SW 2014 (as of two weeks ago). The problem has been going on for quite some time though on many drawings. Most of the drawings I notice it with is assembly drawings with sheet metal parts. I do not have auto insert of centerlines turned on when inserting views onto the sheet because it seems like i end up deleting many of them anyway. So I choose to insert them manually, per the individual views using the "Auto insert, Select View" option. The problem is that many times, not all of the centerlines will populate the view. Some are miss placed in space and dissappear after a "Ctrl-Q" and other times only some of the centersline will be placed in the view. While this is not a huge problem, it does not look good to have missing centerlines.
Also, it seems to be random, but if I manually pick the lines to insert a centerline, only sometimes will it place a correct length of centerline.
Here is a picture of an example.
