We save all of our parts with the file name in a format that has the "part number" on the end of the file name following a period. We reference this part number on BOM and callout tags on exploded views.
Part Filename = <Assembly FileName>.<Part Number> (Example: 1234-10.105)
We have a custom property on each part named "PARTNO" that we are manually filling with the last number (105 in the example).
Is it possible to write this in a calculated field either on the Custom Property or inside a Table like a BOM to avoid having to run a macro?
In Excel I would use something like this: Equation = Replace(PartFileName, AssemblyFileName, "")
If not, can somebody get me started on the macro? I'm very familiar with VB but brand new to SolidWorks.
Below is a quick outline of the steps I would like to do, I just need help getting the correct SolidWorks functions and objects to make it work.
For each Part in Assembly
get PartFileName
get PartNo from PartFileName - (I can handle the string manipulation steps)
assign CustomPartProperty "PartNo" to PartNo
Next Part
Or is there a better way to do this that I'm no aware of? We're using SW 2013 Standard.
