6 Replies Latest reply on Oct 23, 2013 11:24 AM by Matt Fisher
    Testing edges for linearity.
    Matt Fisher
      I have a macro that creates an oriented bounding box around a part given 2 co-planar linear edges as input. I've been testing the edges for linearity with ICurve.IsLine.  My problem is that sometimes the edge curve is a BCurve so IsLine fails. Is there a way to test a BCurve for linearity as a work around?
      The selected edges in the following screenshot fail the IsLine test yet the 3 faces shown are planar and mutually perpendicular.
        • Re: Testing edges for linearity.
          Keith Rice
          Matt,
          I tried these:
          1. Getting ICurve::LineParams - didn't work
          2. Selecting the two adjacent edges and checking for perpendicularity using IMeasure::IsPerpendicular - didn't work because it returned false, even though the measure tool when used in the GUI returns true (odd...)
          3. Converted the edge to a sketch segment in a 3D sketch and then tested if that sketch segment was a line (versus a spline) - this did work. So here's the code for that.
          Dim swEdge As SldWorks.Edge
          Dim swCurve As SldWorks.Curve
          Dim swSketch As SldWorks.Sketch
          Dim swSketchSegment As SldWorks.SketchSegment
          Dim swFeat As SldWorks.Feature
          Dim vSketchSegs As Variant
          Dim i As Integer
          Dim strName As String
              Set swModel = swApp.ActiveDoc
              Set swEdge = swSelMgr.GetSelectedObject6(1, -1)
              Set swCurve = swEdge.GetCurve
              If swCurve.isline = False Then
                  swModel.SketchManager.Insert3DSketch (False)
                  Set swSketch = swModel.SketchManager.ActiveSketch
                  Set swFeat = swSketch
                  strName = swFeat.Name
                  swModel.SketchManager.SketchUseEdge2 (False)
                  vSketchSegs = swSketch.GetSketchSegments
                  If IsEmpty(vSketchSegs) = False Then
                      Set swSketchSegment = vSketchSegs(0)
                      If swSketchSegment.GetType = swSketchLINE Then
                          swModel.SketchManager.Insert3DSketch False
                          swModel.Extension.SelectByID2 strName, "SKETCH", 0, 0, 0, False, 0, Nothing, 0
                          swModel.EditDelete
                          swApp.SendMsgToUser "Edge is linear."
          Keith
          SolidWorks API Tutorials
            Artem Taturevych
            Because line is a minimal segment between two points I would do the following to identify whether this b-curve or line curve is line:
            1) Calculate the distance between end points (vertices of the edge) - this is the length of the line.
            2) Calculate the actual length of the curve: Curve::GetLength3.
            3) Compare #1 and #2. If the comparison satisfies the tolerance the curve is line.
            ____________________________________________________
            Regards,
            Artem Taturevych, Application Engineer at Intercad (Australia)
            translationXpert – add-in to translate SolidWorks models
            myIntercad an integrated tool for SolidWorks Professionals
            LinkedIn SolidWorks API Education Group
