3 Replies Latest reply on Oct 24, 2013 11:09 AM by Charley Saint
    How to check files permission for user
    James Lee
      Hi Guys,
      Is there a way to check user files permission? Currently, I have to login to EPDM for each user, select each file and right click properties to check the file permission (as attached).
      Is there a way to check the permission of all the files instead of choosing one by one to see the permission?
      Can I set all the files permission at one time?
      Thanks in advance!
        • Re: How to check files permission for user
          Charley Saint
          --Updated--
          James,
          Here's a query you can run that dumps it out in a nice format, I've also attached a crp file with the same results. As far as I know you can't set these permissions on multiple files at the same time, most people don't even use these.
          DECLARE @idList varchar(MAX)
          select @idList = COALESCE(@idList + ',', '') + '[' + GroupName + ']'
          FROM (select distinct groupname from
          FilePermissions fp
          inner join GroupS g on g.GroupID = fp.GroupID) a
          DECLARE @replaceList varchar(MAX)
          select @replaceList = COALESCE(@replaceList + ',', '') + 'replace(replace([' + GroupName + '],''1'',''X''),''0'','''') ['+ GroupName + ']'
          FilePermissions fp
          DECLARE @sqlToRun varchar(MAX)
          SET @sqlToRun = '
          select filename, ' + @replaceList + ' from
          (SELECT filename, g.Groupname from
          documents d
          inner join FilePermissions fp on d.DocumentID = fp.DocumentID
          inner join GroupS g on g.GroupID = fp.GroupID)a
          pivot
          count(groupname)
          for groupname in (' + @idList + ')
          ) as pvt'
          EXEC (@sqlToRun)
          Message was edited by: Charley Saint
