2 Replies Latest reply on Oct 21, 2013 6:44 AM by Paul Phoenix
    Problem with Sweep and sketch.
    Paul Phoenix
      I try to write macro and I have few problems.
      First of these is when I draw a rectangle(vSkLines = CType(swDoc.SketchManager.CreateCornerRectangle(-101.7/ 1000, 0.0, 0.0, -98.3 / 1000, -2 / 1000, 0), Array)) in a sketch, add the curve through the x y z points and Sweep it with direction vector. And when I’m editing operation in SolidWorks there is no direction vector there.
      The second problem that I have is when I make second sketch on the same plan as before and make rectangle(vSkLines = CType(swDoc.SketchManager.CreateCornerRectangle(-101.7 / 1000, -0.3 / 1000, 0, -91.7 / 1000, -3.3 / 1000, 0), Array)) which should be  -0.3 on Y axis. When I look in SolidWorks both of rectangle have Y =0.
      I Was Looking in API help and on many forums, and I can’t fix it.
      I attach my macro, and hope that this can be solved.
      Thank you for all help.
      Paul.
        • Re: Problem with Sweep and sketch.
          Artem Taturevych
          For the second issue try to set the SketchManager::AddToDb property to ‘true’  before inserting the sketch rectangle. Do not forget to restore this property value after finish.
          The first issue is not clear to me – could you please clarify?
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
              Paul Phoenix
              Thanks Artem for your answer, but unfortunately It doesn’t help.
              The second problem is about this part of code:
              boolstatus = swDoc.Extension.SelectByID2("Szkic1", "SKETCH", -0.103609986623, 0, 0, False, 1, Nothing, 0)
                      boolstatus = swDoc.Extension.SelectByID2("Krzywa1", "REFERENCECURVES", 0.03897789893665, -0.01380502702305, 0.1061164316121, True, 4, Nothing, 0)
                      boolstatus = swDoc.Extension.SelectByID2("Line1@Szkic2", "EXTSKETCHSEGMENT", 0, -0.007471267454362, 0, True, 128, Nothing, 0)
                      Dim myFeature As Feature = Nothing
                      myFeature = CType(swDoc.FeatureManager.InsertProtrusionSwept3(False, False, 0, False, False, 0, 0, False, 0, 0, 0, 2, True, True, True, 0, True), Feature)
              As You can see ther is selected profile and sweep path, and the third is direction vector. When I run macro SolidWorks make this sweep without this vector. I check it in the API, but everything seems to be correct. The profile has mark 1, the sweep path 4. PathAlign in InsertProtrusionSwept3 function is set to 2 and TtwistCtrlOption is set to 0.
              Regards Paul.
