Ok, I'm cornfused..
I need to create a low-head cap screw for a design, and want to add to the toolbox. Can I use the toolbox setup to do this? I thought maybe I could make a copy of the _ai file and change it directly to what I need, but the copied file doesn't show up in toolbox. I've been reading different posts regarding the custom properties and the toolbox setup but am more confused than when I started.
The other question, if successful in adding the custom fastener, would smart fasteners recongnize it or would I have to add the new fastener manuall to the assy?
thanks!
Joe,
If you are using a standalone toolbox, it is easy to add a custom fastener into an existing one.
In this case, you are adding a Low Head cap screw, which is similar to the regular cap screw, except the head thickness and the socket.
Make sure you make a backup of your toolbox database file before you make any changes.
Now open the assembly file
Try to insert the toolbox part and see if it works
If you have a smart feature, you can try inserting smart fasteners
See below
This is a Metric Low Head screw in an assembly
Hope this helps
