I have created Plate 3, using sweep command. The plate has been created in an assy. dwg using: Insert, new part.
In order to create a manufacturing dwg I have to provide un unfold of the plate. I have tryed to convert the solid part to sheet metal; did not work.
I have tryed to offset each surface and knit all the surfaces together...
Can anyone suggest how to convert to sheet metal and get an unfold
Thank you
Suppress your Chamfer Feature. Then use Insert Bends and Select an Edge...
Be sure you have the desired settings for your K-Factor.
SolidWorks needs constant material thickness. The chamfer causes the issue since SW does not see there as being a constant material thickness. You will also see that SW squared up the draft you have on the edges of your sketch you are sweeping in the Flat Pattern.
Cheers,
Anna
