I am trying to make an exploded view. I got a sub-assembly that has two configuration, Default and an exploded-view configuration.
I then "Configure Component" and select the sub-assembly to be set to exploded-view configuration in the main assembly explode view configuration.
BUT....the sub-assembly is still displayed as in Default configuration...
So what do I do to make the sub-assembly to be shown in exploded view/state?
You will have to create a new exploded view in top level assembly (in case you've not) OR Use/edit an existing exploded view of top level assembly.
Either way do following:
The subassembly explodes in the graphics area, and the steps of the subassembly exploded view appear under Explode Steps.
You might also find this post helpful for your future reference.
