Hi all,
I'm wondering if anyone has seen the following problem before. I'm running SolidWorks 2012, SP 3.0, with Flow Simulation.
I create a new part, which is a simple box-section channel.
Save part.
Create new Flow Simulation Project.
Save part.
Crash.
However, if I go to Options -> System Options -> Performance then check Use Software OpenGL, the problem appears to disappear.
I have a custom hardware setup:
i7-4770k, overclocked to 4.5 GHz.
Corsair H100i water cooler
ASUS Maximus Gene VI MB
Samsung 850 Pro Series 256GB SSD
32GB (4x 8GB) G.SKILL TridentX F3-2400C10D-16GTX
AMD FirePro W5000
Has anyone seen this before?
Hi all,
I have put the video card into an identical hardware setup, but with SolidWorks 2013 installed. Using the same drivers, everything seems to be stable. I suppose whatever the issue, they rectified it with SW 2013.
Mark, the W5000 has been running very stable for me with the exception of this problem. Hopefully, this will be the last of them!
