suppose I have the chip in the picture:
I've run a simulation with SolidWorks Flow Simulation where I have these bounday conditions in an external analysis:
- materials of the chip and small PCB
- heat power of the chip component
- radiation active and radiative surfaces defined
The chip is considered "hanging in the air" and air surrounds it, therefore it loses heat by air convection and radiation.
SolidWorks Flow simulation can give me temperature distribution in the chip assembly, and in the air.
I need to supply chip thermal resistance, how should I calculate it ?
By making an an analogy with electrical current it should be something like:
Thermal resistance = Temperature Delta T between lower surface and upper surface/ Total Heat Flux going through the part
Would this be correct ?
Alex
basic premise is sound.
http://en.wikipedia.org/wiki/Thermal_resistance
what are you inputting the thermal resistance into?
you could always back check your model by setting up a contact resistance problem to confirm your findings.
