I've prepared animation of this spring model:
I can easily animate spring compression through consolidated techniques (like in attached video).
Is there a chanche you can simulate spring compression and torsion at the same time ?
I'm attaching files I used (SolidWorks 2013 version).
Alex
animate only right? not simulate?
can you predict the torsion shape? i think you'd ahve to do the same thing you did to make the spring compress. predict how the model will change and "program" it into your dimension changes.
