Hi -
I have toolbox installed on my computer and want to use it to import fasteners into a part, not an assembly. When I drag the item from tool box to my part, i get a question of
"are you trying to make a derived part?" I click yes, and i get a fastener added to my part. However, it isn't the right size. How do i edit the fastener to be what i need, which in this case is an M6x1.
thanks!!
Joe
Joe,
Start a new assembly, insert the toolbox component into the assembly, configure to your size.
Then save as part file. (this will save your toolbox part as a dumb solid without any features)
This can be done in assembly level or part level (as a copy)
Open your existing part, then click insert part.
Use move command and mate.
Hope this helps
