I would like certain date variables, such as Approved On, to be cleared when copying a file from another file in our EPDM vault.
The variable type is date, so any text value for a default on the data card gets ignored.
I know I can overwrite them during a transition after check in, as well as clearing them using Copy Tree settings,
but I would prefer if they were just cleared on add.
I also tried dispatch, but it gives an error if I put nothing, or something other than a date format when setting a variable.
Hopefully it's something simple that I'm just overlooking.
Any help will be appreciated.
Michael,
May be, I'd say play around with a couple of things, try a text value with a single space in it. I think it has to be set to something to overwrite the custom properties. You may not be able to use a date variable for this, try just a text variable with the field in the data card still tied to a date controller.
