0 Replies Latest reply on Oct 15, 2013 10:21 AM by Jakob Brusewitz
    poCmd.mpoExtra in EdmCmd_TaskLaunch
    Jakob Brusewitz
      Hi.
      I'm trying to get the Task add-in samle to work but now I'm stuck on saving which files was selected during the task initiation.
      In the examle the Sub OnTaskLaunch looks like this (se below) and I get an error when trying to set inst with poCmd.mpoExtra
      The documentation says that "EdmCmd::mpoExtra points to IEdmTaskInstance" @ EdmCmdType.EdmCmd_TaskLaunch
      but for me it does not work. What could be wrong? My code is compiled as .Net 4 and everything else in the example works.
      Private Sub OnTaskLaunch(ByRef poCmd As EdmCmd, ByRef ppoData As System.Array)
        'Display a message box
      where the user types data that is
      passed to the task add-in via IEdmTaskInstance::SetValEx
        Dim v11 As IEdmVault11
        v11 = poCmd.mpoVault
        If v11.MsgBox(poCmd.mlParentWnd, "Hello!" + vbLf + "Are you sure you want to launch the test task?", EdmMBoxType.EdmMbt_YesNo) <> EdmMBoxResult.EdmMbr_Yes Then
          poCmd.mbCancel = True
          Exit Sub
        'Get the property interface used to access the framework
        Dim inst As IEdmTaskInstance
        inst = poCmd.mpoExtra 'Here I get a MsgBox with error "incorrect data"
        inst.SetValEx("MyLaunchVar", "A launch value")
      while it works fine in Sub OnTaskRun
      Private Sub OnTaskRun(ByRef poCmd As EdmCmd, ByRef ppoData As System.Array)
        inst = poCmd.mpoExtra 'Here it's working"
      / Jakob
