Mate References not behaving SW2012
Question asked by Derek Eldridge on Oct 15, 2013
I'm using SW 2012. I'm trying to use mate references on a library part i'm creating, "Hiem". The issue i'm running into is that i have mate references dictated exactly how the example from SolidWorks shows for 2012. Yet, when the Hiem is placed into the rack gear in an assy, only the first cylindrical face mate is established. The other two mates are ignored. If I change the order of the same mates for both parts, I can get them to work. For example, Putting primary in the tertiary spot and moving the others up, order of Secondary Tertiary then Primary.  I am having allot of difficulty with this because sometimes it works properly, and others like this sample will not. You can imagine the inefficiency of changing the order of mate references every time i'm going to use the part. Can someone take a look and tell me what i'm doing wrong?
I've attached two zip files with samples of my issue. The first following the solidworks example of mate references named, "Reference Mates Assy.zip". The other contains the same files with the mate references reordered and called, "Reference Mates Assy new mate order.zip".
SW 2012
My mates:
On HIEM part:
cylindrical face: Concentric
Mate Plane: Coincident
Plane 3: Parallel
On rack gear:
Cylindrical face: Concentric
Face: Coincident
Front Plane: Parallel
From Solidworks Help 2012:
Example of Mate Reference with Multiple Mated Entities
Components bushing, shaft01, and shaft02 each have a mate reference named shaft, defined as follows:
Reference Entity
Primary
Entity
Mate Type
Entity
Mate Type
Entity
Mate Type
bushing
cylindrical face
concentric
planar end face
coincident
face of flat
parallel
shaft01
cylindrical face
concentric
planar end face
coincident
face of flat
parallel
shaft02
cylindrical face
concentric
planar end face
coincident
If bushing is a component of an assembly, and you insert shaft01 into the assembly, the components mate automatically. However, if you insert shaft02 into the assembly, it does not mate automatically with bushing because their mate references do not contain the same number of entities.
bushing01 and shaft01
mate automatically
bushing01 and shaft02
do not mate automatically
