5 Replies Latest reply on Oct 16, 2013 9:23 AM by Jason Hill
    Save drawing as PDF with revision from model
    Jason Hill
      I know this has been answered before (probably many times) but I'm not a programmer and can't seem to make this work.  Basically all I need is a macro that will save a drawing as a PDF using the file name from the drawing and the revision from the referenced model (custom property called "Revision").  What I have used is shown below and it works fine but isn't setup to pull the revision from the referenced model.  I have tried a number of different ways to pull that custom property but just can't get it done.  Any help would be greatly appreciated!
      Dim swApp As Object
      Dim Part As Object
      Set Part = swApp.ActiveDoc
      Part.ViewZoomtofit2
      sPathName = Mid(Part.GetPathName, InStrRev(Part.GetPathName, "\") + 1)
      FilePath = Left(sPathName, InStrRev(sPathName, ".") - 1)
      FilePath = "C:\Test" & FilePath
      Rev = Part.CustomInfo2("", "Revision")
      Part.SaveAs3 FilePath & " RV " & Rev & ".PDF", 0, 0
