Hi all,
Im working on a macro to delete a selected layer in Layers window. The selected layer will be flag/marked by the "On/Off" lightbulb to toggle the visibility in drawing.
To summarize:
Visble (light bulb on) = Layers to be use/keep
Invisible (light bulb of) = Layers to purge/delete
So the macro will delete all the layer that is invisible, while remain the visible intact.
I already found a macro that delete all the layers:-
Dim doc As ModelDoc2
Dim lyrMgr As LayerMgr
Dim v As Variant
Dim i As Integer
Dim count As Integer
Set doc = swApp.ActiveDoc
Set lyrMgr = doc.GetLayerManager
count = lyrMgr.GetCount
v = lyrMgr.GetLayerList
For i = 1 To count - 1
lyrMgr.DeleteLayer (v(i))
Next i
Original link: http://compgroups.net/comp.cad.solidworks/macro-how-to-delete-layers/98701
I need some help to implement the condition that I want to that macro.
Thanks.
