Hi every one.
todey I see an error in photoview.
when I do a render of a file containing a derived part. the Photoview apply scale in the derived part!
look the pictures
solidworks part
Photoview preview
photoview finish
Hi every one.
look the pictures
solidworks part
Photoview preview
photoview finish
what you mean by displacement?
the cover is a derived part with 2 restrictions.
1 - concentric to the finish of the bottle
2.- touch in the finish lip
The appearance on the cap. What is it? For the cap appearance in the "surface finish" tab is it set to have displacement?
Check the settings on the Advanced tab for that Appearance. What is the setting for Displacement?
When you select the Advanced button you will get several more tabs of settings for that Appearance.
Cheers,
Anna
Anna, thanks for your answer.
this appearance don't have advanced settings because is not native from solidworks.
is a MODO appearance.
this only happens to me with sw2014.
Post the Modo appearance file you downloaded. We can open it in Modo and check if the file has displacement.
Cheers,
Anna
See if this will work.... I changed a couple settings in Modo and saved a new preset.
Before...
After......
Should work for you. I render the above image in SW2014 with your original preset and the new one I saved out of Modo 701 SP2.
Displacement is physically changing your part. Making it larger. You can see this in the Before image in my model.
Cheers,
Anna
Before...
After......
Cheers,
Anna
