Thomas Allsup
MLC-CAD SolidWorks 2014 Rollout
Discussion created by Thomas Allsup on Oct 10, 2013
Latest reply on Oct 11, 2013 by Justin Strempke
Top Golf Dallas, TX
June 10,2014
Attendees: 42 at beginning, 60 at end
Theme:  Design without Limits
EPDM:  Improvements (Don't use this so I was checking emails)
User Interface Visualization: Color of menus, History Folder (like Favorites folder), Save as Copy and open as third option (allows assembly to also save copy of parts with a prefix), Section view now allows to include and exclude components
Rendering: Save as PNG with lots of options (poor mans rendering), solar study to show sun rise and setting on the product
Design tools: Autoscaling sketch, lasso, path length dimension
Sketch Picture: Autoscale a sketch picture based on dimension and change the angle of the picture
Spline Enhancements:  Spline with auto tangency, style spline draws the lines not the spline, replace an entity in a skecth and can make original entity deleted or construction lines
Fillets:  Two new options on fillets: conic rho, conic radius
Simulation: Compare results across configurations
Edrawings:  iPAD open 3DContent Central, Animation
Electrical:  Improvements (Don't use this so I was checking emails)
Drawings: Replace view, reattach balloon, change notes to all upper case, automatically put virtual sharps during dimensions, split dual dimensions,  adding sheets is now in document properties, going to multiple columns to BOMs
Sheet Metal:  You can select face to make flat pattern, Formed Gusset, lofted bend
Weldments: Configure Profile, Configure Equation, slots in hole wizard
Assemblies:  Explode Rotation, lock rotation on concentric mate, you can find feature in a assembly and you can see the mates that use that surface, smart sensitivity, use control on surface and brings up mate menu when you release control key, curve driven component pattern
