11 Replies Latest reply on Sep 2, 2016 4:43 AM by roberto gennari
    Get XYZ coordinates for Preselected objects using DMouseEvents_MouseMoveNotify
    Jacob Corder
      I am in need of getting the closest possible location on a PRESELECTED planar face for this example. I am using DPartEents_UserSelectionPreNotify to capture the preselected object, then using DMouseEvents_MouseMoveNotify which gives me the X and Y Location in Pixels on the monitor. See Code Below. this gives me the appearance of having the location but is quite far away in model space. I Need it relative to the face that is preselected. I Know what one of the XYZ Values are from the face. i need to take that known value along with i am assuming the rotation of the model and
      Public Function GetXYZFromModelViewXY(ByVal ModDoc As ModelDoc2, ByVal ModViewX As Double, ByVal ModViewY As Double, ByVal ReferenceFace As Face2, ByVal SetToFace As Boolean) As Double()
              GetXYZFromModelViewXY = Nothing
              Dim ModViewLocation() As Double = Nothing
              Dim ModelViewPoint As MathPoint = Nothing
              If IsNothing(ModDoc) = False And IsNothing(ReferenceFace) = False Then ModelViewPoint = iSwApp.IGetMathUtility.CreatePoint(New Double(2) {ModViewX, ModViewY, 0})
              If IsNothing(ModDoc.IActiveView) = False And IsNothing(ModelViewPoint) = False Then
                  Dim ModelSpacePoint As MathPoint = ModelViewPoint.IMultiplyTransform(ModDoc.IActiveView.Transform.Inverse)
                  If IsNothing(ModelSpacePoint) = False Then
                      ReDim ModViewLocation(2)
                      For i = 0 To 2
                          ModViewLocation(i) = ModelSpacePoint.ArrayData(i)
                      Next
                  ModelSpacePoint = Nothing
              ModelViewPoint = Nothing
              Return ModViewLocation
          End Function
      this will return the location that i use to create a temporary body as a preview of what will happen if a user selects the face. The temporary body is not selectable so i do not have any issues with that.
      This second image shows the issue as the preview is supposed to be flat to the face as the feature above it is. if i move the mouse to the right it completely disappears into the block. this is all relative to the rotation angle of the model.
      i am assuming i need to take my x y and z values that i  am recieving from this function and triangulate the distances so the value that would put it on the face is correct.
      for example i am recieving in meters
      x = 0.0374432120
      Y = 0.0037049424
      Z = -0.0212748091
      in this case Y should equal 0.0
      attached is also the model view orientation transformation matrix. i might not need to use it but i am assuming it is what determines my rotational angle.
      Sorry if this is confusing. post any comments that could help or help me better understand how to use transforms.
        • Re: Get XYZ coordinates for Preselected objects using DMouseEvents_MouseMoveNotify
          Artem Taturevych
          Have you tried the SelectionMgr::GetSelectionPoint2 method?
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
            Jacob Corder
            Alright. I Was able to figure out how to do this. This is not the best way to do this but it does work.
            Limitations are as follows
            It only works on a planar face
            The Face Must have a normal value of 1 or -1  so (0,1,0) or (-1,0,0) ect
            You must know the XY Values returned from mouse events
            The only thing needed to find is the Z Value that goes into the point that is transformed by the modelview.Transform.Inverse. This Z Value is treated as depth to screen into Model Space.
            First thing needed is getting the point with a z value of 0, and a z value of 1 i was able to determine the depth change in pixels to that face. by running the transformation 3 times it is able to get within a very small distance to that face, then use Face2.getclosestpointOn and the location is projected exactly on that face.
                Public Function PreSelectionPoint(ByVal ModDoc As ModelDoc2, ByVal ModViewX As Double, ByVal ModViewY As Double, ByRef RefFace As Face2) As Double()
                    Dim ModViewLocation(2) As Double
                    If IsNothing(ModDoc) = False And IsNothing(RefFace) = False Then
                        Dim ModView As ModelView = ModDoc.IActiveView
                        If IsNothing(ModView) = False Then
                            Dim MathUtil As MathUtility = iSwApp.IGetMathUtility
                            Dim KnownDimMultiplier As Double = 1
                            Dim ModViewTransform As MathTransform = ModView.Transform
                            Dim KnownFaceCoord As Integer = KnownFaceCoordinate(RefFace)
                            Dim CompareVals(1, 2) As Double
                            'Dim LastVals(2) As Double
                            'Dim ThisVals(2) As Double
                            Dim Distances(1) As Double
                            Dim KnownVal As Double = 0
                            Dim ClosestPointOnFace As Object = Nothing
                            'get a point in the model that is projected from the X,Y Coordinates that are retrieved from MouseEvents
                            Dim ModelViewPoint As MathPoint = MathUtil.CreatePoint(New Double(2) {ModViewX, ModViewY, 0})
                            Dim ModelSpacePoint As MathPoint = ModelViewPoint.IMultiplyTransform(ModViewTransform.Inverse)
                                For i = 0 To 2
                                    CompareVals(0, i) = ModelSpacePoint.ArrayData(i)
                                Next
                           'Get the known value on the face
                            ClosestPointOnFace = RefFace.GetClosestPointOn(ModelViewPoint.ArrayData(0), ModelViewPoint.ArrayData(1),                          ModelViewPoint.ArrayData(2))
                            KnownVal = ClosestPointOnFace(KnownFaceCoord)
                            'Increase the Z Value by 1 giving a difference between the previous point and this point, this gives us depth change per pixel.
                            ModelViewPoint = MathUtil.CreatePoint(New Double(2) {ModViewX, ModViewY, 1})
                            ModelSpacePoint = ModelViewPoint.IMultiplyTransform(ModViewTransform.Inverse)
                                For i = 0 To 2
                                    CompareVals(1, i) = ModelSpacePoint.ArrayData(i)
                                Next
                            For i = 0 To 1
                                Distances(i) = KnownVal - CompareVals(i, KnownFaceCoord)
                            Next
                            Dim ChangePerPixel = Distances(0) - Distances(1)
                            Dim ModViewZ As Double = (Distances(0) / ChangePerPixel)
                            ModelViewPoint = MathUtil.CreatePoint(New Double(2) {ModViewX, ModViewY, ModViewZ})
                                For i = 0 To 2
                                Next
                            Dim DistanceToFace As Double = Math.Abs(ModViewLocation(KnownFaceCoord)) - Math.Abs(KnownVal)
                            Debug.Print("Distance to Known Val on Face = " & DistanceToFace)
                            Select Case DistanceToFace
                                Case -0.00254 To 0.00254
                                    ClosestPointOnFace = RefFace.GetClosestPointOn(ModViewLocation(0), ModViewLocation(1), ModViewLocation(2))
                                    For i = 0 To 2
                                        ModViewLocation(i) = ClosestPointOnFace(i)
                                    Next
                                    Debug.Print("within .1 Inches")
                              End Select
                End Function
            Public Function KnownFaceCoordinate(ByVal RefFace As Face2) As Integer
                    Dim KnownCoord As Integer = -1
                    If IsNothing(RefFace) = False Then
                        Dim Facenorm() As Double = JEMFaces.FaceNormal(RefFace, True)
                        If IsNothing(Facenorm) = False Then
                            For i = LBound(Facenorm) To UBound(Facenorm)
                                If Facenorm(i) <> 0 Then
                                    If KnownCoord = -1 And Facenorm(i) <> 0 Then
                                        KnownCoord = i
                                    Else
                                        Debug.Print("there are 2 normals that are not 0 at KnownFaceCoordinate")
                            Next
                    Return KnownCoord
                End Function
                roberto gennari
                Hallo,
                I'm trying to annex the code to understand it better, but I do not understand what it refers to the line "JEMFaces":
                                            KnownCoord = i
                                        Else
                                Next
                        Return KnownCoord
                    End Function
                The "RefFace" is the face reference of the sketch in the planar face, but I don't undestand what's  JEMFaces object.
                Roberto
                    Jacob Corder
                    JEMFaces is a class i have in my API Code. just Use RefFace.Normal or insert this function call and change JEMFaces.FaceNormal() to FaceNormal()
                    Public Function FaceNormal(ByVal SelFace As Face2, Optional ByVal RndToTenPlaces As Boolean = True) As Double()
                            FaceNormal = Nothing
                            Dim FaceNorm() As Double = Nothing
                            If IsNothing(SelFace) = False Then
                                Dim FNorm As Object = SelFace.Normal
                                If IsNothing(FNorm) = False Then
                                    If UBound(FNorm) >= 2 Then
                                        ReDim FaceNorm(2)
                                        For i = 0 To 2
                                            FaceNorm(i) = FNorm(i)
                                        Next
                                        For i = 0 To 2
                                            If Math.Round(FaceNorm(i), 10) = 0 Then
                                                FaceNorm(i) = 0
                                            Else
                                                If RndToTenPlaces = True Then
                                                    FaceNorm(i) = Math.Round(CDbl(FaceNorm(i)), 10)
                                                Else
                                                    FaceNorm(i) = CDbl(FaceNorm(i))
                                        Next
                            Return FaceNorm
                        End Function
                    This function just removes additional values that Solidworks passes. Solidworks works at 10 decimal places, but will often return much greater than 10. this function will trim those values.
                        roberto gennari
                        Hallo Jacob,
                        i Tried the new code, but I have a probelm in the call
                        KnownFaceCoord As Integer = FaceNormal(RefFace)
                        My preconditions are a part open and with a edit 2D sketch, the RefFace is the face when the 2D sketch is.
                        this is my code, can you try it, please?
                        In the Form code I have:
                        Dim pSketch As Sketch
                        Dim MyFeature As Sketch
                        MyFeature = swModel.GetActiveSketch2
                        pSketch = MyFeature.GetSpecificFeature2
                        pEntity = pSketch.GetReferenceEntity(nEntType)
                        If nEntType = 2 Then 'se lo schizzo è appoggiato in una una faccia
                        Debug.Print("Face Selected!")
                        Debug.Print("  Normal   = (" + Str(vNormal(0)) + "," + Str(vNormal(1)) + "," + Str(vNormal(2)) + ")")
                        In the MouseMoveNotify I have this code:
                        Public Function TheMouse_MouseMoveNotify(ByVal X As Long, ByVal Y As Long, ByVal WParam As Long) As Long
                        Debug.Print(X & "  " & Y)
                        Debug.Print("wParam= " & WParam)
                        Dim ModViewX As Double = CDbl(X)
                        Dim ModViewY As Double = CDbl(Y)
                        PreSelectionPoint(swModel, ModViewX, ModViewY, RefFace)
                        End Function
                        Dim MathUtil As MathUtility = swApp.IGetMathUtility
                        Dim KnownFaceCoord As Integer = FaceNormal(RefFace)                          <---- HIRE A HAVE THE PROBLEM
                        End Function
                        '''' Like your exsample
                        End Function
                        Thanks and have you a nice day
                            Jacob Corder
                            Add This Function
                            'This will only work on Front, Top, Left, Right, Back, and Bottom Faces. the return for face Normal must be in any order 0,0,1 or 0,0,-1.
                            otherwise the function is not set up to handle non Ortho Faces.
                                        Dim Facenorm() As Double = FaceNormal(RefFace, True)
                                                        KnownCoord = i
                                                    Else
                                            Next
                                    Return KnownCoord
                                End Function
                                roberto gennari
                                Hallo,
                                I talk again in this thread because I wanted to implement the code also working on faces that havn't face Normal in any order 0,0,1 or 0,0,-1.
                                How should I proceed to do it that works on different normal faces ? Could someone help me in the code steps?
                                Thanks to every body
                                Roberto
                                  roberto gennari
                                  Hallo,
                                  I'm sorry, but after so many attempts have failed to find a solution to make this beautiful code on sloped faces (only planar).
                                  Someone would be able to help me, I'd be very grateful.
                                  Thanks to everibody
                                  Roberto
                                                              KnownCoord = i
                                                          Else
                                                  Next
                                          Return KnownCoord
                                      End Function
