2 Replies Latest reply on Oct 12, 2013 3:34 PM by Thomas Thanner
    Pack&Go API: setDocumentSaveToNames fails
    Thomas Thanner
      Hi all,
      I frequently have to export a large assembly using pack&go, but I to not want to export parts which are located in a certain sub-directorty. So I tried to automatize the process using a VBA macro based on some code I found in the API-Doc and some code from this forum:
      Dim swModelDocExt As SldWorks.ModelDocExtension
      Dim swPackAndGo As SldWorks.PackAndGo
      Dim oPaths As Variant
      Dim listPaths() As Variant
      Dim strCurrentPath As String
      Dim strSaveToPath As String
      Dim oResults As Variant
      Dim i As Long
      Dim nCount As Long
      Dim retval As Boolean
      Dim strDebug As String
      Dim strFinalPaths() As String
      Public Sub main()
          strSaveToPath = "F:\tmp\cad\"
          Set swModel = swApp.ActiveDoc
          Set swModelDocExt = swModel.Extension
          Set swPackAndGo = swModelDocExt.GetPackAndGo
          swPackAndGo.IncludeDrawings = True
          swPackAndGo.IncludeSimulationResults = False
          retval = swPackAndGo.GetDocumentSaveToNames(oPaths, Nothing)
          nCount = UBound(oPaths)
          ReDim listPaths(nCount)
          Debug.Print ""
          Debug.Print "~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~"
          Debug.Print "Initial file list:"
          For i = 0 To nCount
              strDebug = "  " & i & ". " & oPaths(i) & "    ->    "
              If InStr(LCase(oPaths(i)), "\mech\bibliothek\") <> 0 Then
                  Debug.Print strDebug & "SKIPPED"
                  listPaths(i) = Empty
              Else
                  strCurrentPath = Left(oPaths(i), InStrRev(oPaths(i), "\"))
                  strCurrentPath = Replace(oPaths(i), strCurrentPath, strSaveToPath)
                  Debug.Print strDebug & strCurrentPath
                  listPaths(i) = strCurrentPath
          Next i
          Debug.Print "strFinalsPaths:"
          ReDim strFinalPaths(nCount)
          For i = 0 To nCount
              strFinalPaths(i) = listPaths(i)
              Debug.Print "  " & i & ". " & strFinalPaths(i)
          Next i
          retval = swPackAndGo.SetDocumentSaveToNames(strFinalPaths)
          Debug.Print "UBound(oPaths)=" & UBound(oPaths) & "; UBound(strFinalPaths)=" & UBound(strFinalPaths)
          Debug.Print ("Save-to names successfuly set in pack and go object: " & retval)
          Debug.Print "Final file list:"
          For i = 0 To UBound(oPaths)
              Debug.Print "  " & i & ". " & oPaths(i)
          Next i
      My problem is: "retval = swPackAndGo.SetDocumentSaveToNames(strFinalPaths)" fails, and I have no clue why.
      The arrays "oPaths" and "strFinalPaths" both have same size (75 items) and it neither does matter whether I include drawings or not, nor whether I have some empty strings in "strFinalPaths" or not.  The destination directory exists, too.
      More hints: The source files are all located on a network drive. I am using a German 64bit SolidWorks2013SP 4.0 on Windows7 professional with latest updates
      Any hint why "SetDocumentSaveToNames" does fail are more than welcome.
      Thomas
      P.S.: (Partial) debug output looks like this:
        33. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\deckel_lang_bolzen_01.sldasm
      F:\tmp\cad\deckel_lang_bolzen_01.sldasm
        34. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\deckel_kurz_blech_01.sldprt
      F:\tmp\cad\deckel_kurz_blech_01.sldprt
        35. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\deckel_kurz_bolzen_01.sldasm
      F:\tmp\cad\deckel_kurz_bolzen_01.sldasm
        36. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\jst\jst_s4b-eh.sldprt
      SKIPPED
        37. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\jst\jst_s2b-eh.sldprt
      SKIPPED
        38. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\ecomp\bma150.sldprt
      SKIPPED
        39. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\jst\jst_b_4b-eh-a.sldprt
      SKIPPED
        40. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\baugruppen\mtir\mtir-uif-v3\mtir_uif_v3-pcb.sldprt
      SKIPPED
        41. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\ecomp\l1206.sldprt
      SKIPPED
        42. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\shielding_1.sldprt
      SKIPPED
        43. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\insulator_1.sldprt
      SKIPPED
        44. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\pins.sldprt
      SKIPPED
        45. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\pins_2.sldprt
      SKIPPED
        46. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\pins_3.sldprt
      SKIPPED
        47. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\pins_4.sldprt
      SKIPPED
        48. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\pins_5.sldprt
      SKIPPED
        49. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\651305142821.sldasm
      SKIPPED
        50. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\baugruppen\mtir\mtir-uif-v3\mtir_uif_v3.sldasm
      SKIPPED
        51. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\frontblende_01.sldprt
      F:\tmp\cad\frontblende_01.sldprt
        52. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\monitore\eyevis\eye-lcd-8400-qhd-le.sldprt
      SKIPPED
        53. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\z_blech_blech_01.sldprt
      F:\tmp\cad\z_blech_blech_01.sldprt
        54. \\lxserv2\document\mech&pics\solidworks\solidworks_data\copiedparts\pem cls-m3-1 ---n.sldprt
      F:\tmp\cad\pem cls-m3-1 ---n.sldprt
        55. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\z_blech_bolzen_01.sldasm
      F:\tmp\cad\z_blech_bolzen_01.sldasm
        56. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\ecomp\tssop16.sldprt
      SKIPPED
        57. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\baugruppen\mtir\xmt-edge-v10\xmt-edge-pcbn.sldprt
      SKIPPED
        58. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\baugruppen\mtir\xmt-edge-v10\xmt-edge-v10n.sldasm
      SKIPPED
        59. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\eckwinkel_blech_01.sldprt
      F:\tmp\cad\eckwinkel_blech_01.sldprt
        60. p:\solidworks\solidworks_data\copiedparts\pem bsos-m3-8 ---n.sldprt
      F:\tmp\cad\pem bsos-m3-8 ---n.sldprt
        61. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\eckwinkel_bolzen_01.sldasm
      F:\tmp\cad\eckwinkel_bolzen_01.sldasm
        62. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\richco\n-3e.sldprt
      SKIPPED
        63. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt-01_00913_013-uebersicht_01-a1.slddrw
      F:\tmp\cad\xmt-01_00913_013-uebersicht_01-a1.slddrw
        64. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt-01_00913_003-uebersicht-a1.slddrw
      F:\tmp\cad\xmt-01_00913_003-uebersicht-a1.slddrw
        65. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt-01_00913_003-uebersicht_intern-a1.slddrw
      F:\tmp\cad\xmt-01_00913_003-uebersicht_intern-a1.slddrw
        66. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt-01_00913_003-uebersicht-a1_old.slddrw
      F:\tmp\cad\xmt-01_00913_003-uebersicht-a1_old.slddrw
        67. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt-01_00913_009-boden_kurz_01-a1.slddrw
      F:\tmp\cad\xmt-01_00913_009-boden_kurz_01-a1.slddrw
        68. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt-01_00913_008-boden_lang_01-a1.slddrw
      F:\tmp\cad\xmt-01_00913_008-boden_lang_01-a1.slddrw
        69. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt-01_00913_011-deckel_kurz_01-a1.slddrw
      F:\tmp\cad\xmt-01_00913_011-deckel_kurz_01-a1.slddrw
        70. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt-01_00913_010-deckel_lang_01-a1.slddrw
      F:\tmp\cad\xmt-01_00913_010-deckel_lang_01-a1.slddrw
        71. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt-01_00913_007-eckwinkel_01-a1.slddrw
      F:\tmp\cad\xmt-01_00913_007-eckwinkel_01-a1.slddrw
        72. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt-01_00913_012-frontblende_01-a1.slddrw
      F:\tmp\cad\xmt-01_00913_012-frontblende_01-a1.slddrw
        73. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt-01_00913_004-scheibe-a1.slddrw
      F:\tmp\cad\xmt-01_00913_004-scheibe-a1.slddrw
        74. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\baugruppen\mtir\xmt-edge-v10\xmt_edge_v10-01_00913_002-a3.slddrw
      SKIPPED
        75. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt-01_00913_005-z_blech_01-a1.slddrw
      F:\tmp\cad\xmt-01_00913_005-z_blech_01-a1.slddrw
      strFinalsPaths:
        0. F:\tmp\cad\xmt_generic_01.sldasm
        1. F:\tmp\cad\01_parameters.txt
        2. F:\tmp\cad\scheibe_innen_01.sldprt
        3. F:\tmp\cad\scheibe_aussen_01.sldprt
        4. F:\tmp\cad\pvb_folie_01.sldprt
        5. F:\tmp\cad\vsg_01.sldasm
        6. F:\tmp\cad\epdm_bezel_lang_01.sldprt
        7. F:\tmp\cad\epdm_bezel_kurz_01.sldprt
        8. F:\tmp\cad\bezel_kurz_01.sldprt
        9. F:\tmp\cad\bezel_lang_01.sldprt
        10. F:\tmp\cad\vhb_lang_01.sldprt
        11. F:\tmp\cad\vhb_kurz_01.sldprt
        12.
        13.
        14.
        15.
        16.
        17.
        18.
        19.
        20.
        21.
        22. F:\tmp\cad\epdm_boden_lang_01.sldprt
        23. F:\tmp\cad\epdm_boden_kurz_01.sldprt
        24. F:\tmp\cad\boden_lang_blech_01.sldprt
        25. F:\tmp\cad\pem bsos-3.5m3-12 ---n.sldprt
        26. F:\tmp\cad\pem bs-m5-2 ---n.sldprt
        27. F:\tmp\cad\boden_lang_bolzen_01.sldasm
        28. F:\tmp\cad\boden_kurz_blech_01.sldprt
        29. F:\tmp\cad\pem cls-m3-2 ---n.sldprt
        30. F:\tmp\cad\boden_kurz_bolzen_01.sldasm
        31. F:\tmp\cad\deckel_lang_blech_01.sldprt
        32. F:\tmp\cad\pem bsos-m3-14 ---n.sldprt
        33. F:\tmp\cad\deckel_lang_bolzen_01.sldasm
        34. F:\tmp\cad\deckel_kurz_blech_01.sldprt
        35. F:\tmp\cad\deckel_kurz_bolzen_01.sldasm
        36.
        37.
        38.
        39.
        40.
        41.
        42.
        43.
        44.
        45.
        46.
        47.
        48.
        49.
        50.
        51. F:\tmp\cad\frontblende_01.sldprt
        52.
        53. F:\tmp\cad\z_blech_blech_01.sldprt
        54. F:\tmp\cad\pem cls-m3-1 ---n.sldprt
        55. F:\tmp\cad\z_blech_bolzen_01.sldasm
        56.
        57.
        58.
        59. F:\tmp\cad\eckwinkel_blech_01.sldprt
        60. F:\tmp\cad\pem bsos-m3-8 ---n.sldprt
        61. F:\tmp\cad\eckwinkel_bolzen_01.sldasm
        62.
        63. F:\tmp\cad\xmt-01_00913_013-uebersicht_01-a1.slddrw
        64. F:\tmp\cad\xmt-01_00913_003-uebersicht-a1.slddrw
        65. F:\tmp\cad\xmt-01_00913_003-uebersicht_intern-a1.slddrw
        66. F:\tmp\cad\xmt-01_00913_003-uebersicht-a1_old.slddrw
        67. F:\tmp\cad\xmt-01_00913_009-boden_kurz_01-a1.slddrw
        68. F:\tmp\cad\xmt-01_00913_008-boden_lang_01-a1.slddrw
        69. F:\tmp\cad\xmt-01_00913_011-deckel_kurz_01-a1.slddrw
        70. F:\tmp\cad\xmt-01_00913_010-deckel_lang_01-a1.slddrw
        71. F:\tmp\cad\xmt-01_00913_007-eckwinkel_01-a1.slddrw
        72. F:\tmp\cad\xmt-01_00913_012-frontblende_01-a1.slddrw
        73. F:\tmp\cad\xmt-01_00913_004-scheibe-a1.slddrw
        74.
        75. F:\tmp\cad\xmt-01_00913_005-z_blech_01-a1.slddrw
      UBound(oPaths)=75; UBound(strFinalPaths)=75
      Save-to names successfuly set in pack and go object: Falsch
      Final file list:
        0. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\xmt_generic_01.sldasm
        1. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\01_parameters.txt
        2. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\scheibe_innen_01.sldprt
        3. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\scheibe_aussen_01.sldprt
        4. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\pvb_folie_01.sldprt
        5. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\vsg_01.sldasm
        6. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\epdm_bezel_lang_01.sldprt
        7. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\epdm_bezel_kurz_01.sldprt
        8. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\bezel_kurz_01.sldprt
        9. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\bezel_lang_01.sldprt
        10. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\vhb_lang_01.sldprt
        11. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\vhb_kurz_01.sldprt
        12. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\baugruppen\mtir\mtir-sc-v30\mtir-sc-v30_pcb.sldprt
        13. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\baugruppen\mtir\mtir-sc-v30\kingbright_l-5603_body.sldprt
        14. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\baugruppen\mtir\mtir-sc-v30\mtir-sc-v30_electronics.sldprt
        15. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\6871xx14022_pin.sldprt
        16. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\6871xx14022_patte.sldprt
        17. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\6871xx14022_patte_2.sldprt
        18. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\68711814022.sldprt
        19. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\68711814022_cap.sldprt
        20. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\stecker_buchsen\wuerth\68711814022.sldasm
        21. \\lxserv2\document\mech&pics\solidworks\mech\bibliothek\baugruppen\mtir\mtir-sc-v30\mtir-sc-v30.sldasm
        22. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\epdm_boden_lang_01.sldprt
        23. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\epdm_boden_kurz_01.sldprt
        24. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\boden_lang_blech_01.sldprt
        25. p:\solidworks\solidworks_data\copiedparts\pem bsos-3.5m3-12 ---n.sldprt
        26. \\lxserv2\document\mech&pics\solidworks\solidworks_data\copiedparts\pem bs-m5-2 ---n.sldprt
        27. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\boden_lang_bolzen_01.sldasm
        28. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\boden_kurz_blech_01.sldprt
        29. \\lxserv2\document\mech&pics\solidworks\solidworks_data\copiedparts\pem cls-m3-2 ---n.sldprt
        30. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\boden_kurz_bolzen_01.sldasm
        31. \\lxserv2\document\mech&pics\solidworks\mech\xmt\konstruktion_01\deckel_lang_blech_01.sldprt
        32. p:\solidworks\solidworks_data\copiedparts\pem bsos-m3-14 ---n.sldprt
        • Re: Pack&Go API: setDocumentSaveToNames fails
          Keith Rice
          The IPackAndGo interface is buggy unfortunately. You can get this API call to work, I believe, if you use it in conjunction with IPackAndGo::SetSaveToName. I demonstrate this our Macro Library in the free macro titled "Create pack and go with specified custom property as prefix". That might be of some help to you. Good luck.
          Keith
          SolidWorks API Tutorials
              Thomas Thanner
              Hi Keith!
              thanks for the answer and the hints. Unfortunately your (excellent!) macro example did not help.
              After doing some systematic experimenting by myself, I finally found the cause of my trouble:
              My parts and assemblies make massive use of equations. And these equations are linked to the text file "01_parameters.txt". Consequently IPackAndGo automatically adds this ".txt" file to the list of documents to copy. But the call to "SetDocumentsSaveToNames()" fails, if there are any non SW documents in this list!
              My Solution is:
              1) Remove all non SW documents (i.e. documents not ending on "sldprt", "sldasm", or "slddrw") from the list and save them for later.
              2) Remove all other unwanted documents from the list
              3) Call "SetDocumentSaveToNames()", which succeeds this time.
              4) Add previously saved documents as external files using "AddExternalDocuments"
              5) Call "SetSaveToName()" with the new path to adjust the paths for the external documents
              6) Call "SavePackAndGo()"
              And the magic happens
              Now all I have to do is to figure out how to adjust the references in my drawings and the linked parameter file in my models...
              Thomas
