I'm trying to create a scale 1:1 drawing of an assembly which I can take to a special store to get printed (the assembly is 30'' by 30'' and it is crucial that it is printed on one piece of paper). I created a custom size paper for the drawing and then scaled the assembly 1:1. When I export the drawing to pdf the scaling is not preserved (i.e. at 100% zoom the assembly is not the same size on the screen as it should be in reality). Is it possible to export the file to pdf with the exact same scaling? How about other file types?
Thank you,
Eyal
Instead of SaveAs PDF, try print PDF (using CutePDF or Primo PDF) and set the scale as 100%.
Both CutePDF and Primo PDF are free pdf software which will create a PDF of the document and option similar to a document/file printer.
