7 Replies Latest reply on Feb 5, 2015 12:30 PM by Devon Lybbert
    link cutlist to custom property
    Bob Gratton
      I do a lot of assembly of sheet metal.  In my BOM I need to use the cutlist ( width, lenght..) information without have 2 lines for each part ( making by the indented option ) .
      I see only 2 way. First, use the INdented option and delete each Part Only line. The second way, by copying the cutlist property a want to the part custom property and use the PART ONLY bom.
      I prefer the second way to reduse the risk on error.
      My question is, there is a way to link the cutlist pproperty to the model custom properrty in a way that is updated when the value change??
      I know how to make macro to make what i want, but  i have to run my macro each time.
      I see a video  with MACRO FEATURE can make this, but a don't know how to upgrade my macro to a macro feature.
      Did some one have a tutorial???  A macro feature is the same thing of a Custom feature??
        • Re: link cutlist to custom property
          Keith Rice
          Bob,
          You could use a macro feature or you could use an equation-triggered macro if you want code to run on every rebuild (or whenever some other event occurs---as long as a delegate exists for that event in swAppNotify_e., swPartNotify_e, swDrawingNotify_e, etc). I would recommend an ETM. Macro features are difficult to implement and maintain, and I would only recommend them when you need a custom feature to add to your feature tree.
          Keith
          SolidWorks API Tutorials
              Bob Gratton
              Thank Keith
              It work more than i expect.    When i quit the Equation Manager, it give me a syntax error, but all work fine.
              The exemple in the link do the same thing, so, i don't worry about it.
                Bob Gratton
                Hi Keith
                It' s  wierd.   My equation triggered macro work just the first time a making it.   Yesterday i re-work on my project and the Macro did't work.
                I notice that in the exemple giving in the equation-triggered macro the EVALUATES TO is 1, and in my part is nothing.   Also now, when I import the equation #1   my Solidworks crash but not with the equation #3.  I just try to import equation #2 without having the macro in the Design Binder and no problem
                equation #1    : "Var2"= 1::swApp.RunAttachedMacro "CutList_to_prop.swp" , "mMain" , "main"
                equation #2    : "Var4"= 1::swApp.RunAttachedMacro "rename bodies.swp" , "mMain" , "main"
                equation #3    : "Var3"= "1::swApp.RunAttachedMacro" "CutList_to_prop.swp" , "mMain" , "main"
                I don't understand because i change nothing in on my computer.
                Please, Can you help on that ???
                this is my code:
                Dim thisFeat As SldWorks.Feature
                Dim thisSubFeat As SldWorks.Feature
                Dim custPropMgr As SldWorks.CustomPropertyManager
                Dim retValue As Integer
                Dim retDescription As String
                Dim retDescription1 As String
                Dim retLENGTH As String
                Dim retLENGTH1 As String
                Dim retWidth As String
                Dim retWidth1 As String
                Dim retSheet As String
                Dim retSheet1 As String
                Dim names As Variant
                Dim cutListFolder As SldWorks.BodyFolder
                Dim boolstatus As Boolean
                Dim value As Integer
                Set swModel = swApp.ActiveDoc
                Set thisFeat = Application.SldWorks.ActiveDoc.FeatureByName("Solid Bodies")
                Set cutListFolder = thisFeat.GetSpecificFeature2
                Debug.Print cutListFolder.SetAutomaticCutList(True)
                    If Not cutListFolder Is Nothing And cutListFolder.UpdateCutList Then
                    Debug.Print "Updated"
                    Set thisSubFeat = thisFeat.GetFirstSubFeature
                        Do While Not thisSubFeat Is Nothing
                            If thisSubFeat.GetTypeName = "CutListFolder" Then Set cutListFolder = thisSubFeat.GetSpecificFeature2
                            If Not cutListFolder Is Nothing And cutListFolder.GetBodyCount > 0 Then
                                Set custPropMgr = thisSubFeat.CustomPropertyManager
                                  names = custPropMgr.GetNames
                                    If UBound(Filter(names, "Bends")) > -1 Then
                                            boolstatus = custPropMgr.Get4("Bounding Box Width", True, retWidth, retWidth1)
                                            boolstatus = custPropMgr.Get4("Bounding Box Length", True, retLENGTH, retLENGTH1)
                                            bRet = swModel.DeleteCustomInfo2("", "Long")
                                            pbRet = swModel.AddCustomInfo3("", "Long", swCustomInfoText, retLENGTH1)
                                            bRet = swModel.DeleteCustomInfo2("", "Larg")
                                            pbRet = swModel.AddCustomInfo3("", "Larg", swCustomInfoText, retWidth1)
                                    If UBound(Filter(names, "ANGLE1")) > -1 Then
                                                boolstatus = custPropMgr.Get4("LENGTH", True, retLENGTH, retLENGTH1)
                            Set thisSubFeat = thisSubFeat.GetNextSubFeature
                        Loop
                Devon Lybbert
                This discussion should give you a very good start:
                Macro to Extract from Cutlist Item 1 and place in Custom Properties
                This is using a macro, but the macro will run on each rebuild.
