Hi, recently I have been beginning designing support frames for small things like tables and such. I have tried to use the study advisor to get my simulation going but without result. I think that is because of wrong work flow. What i do now is design the frame, add few weldments in the form of gaussed/filled bead and then try to push it through the simulation.
Here is my problem:
1. Probably wrong work process
2. Non-success simulation due to multiple errors when i try to simulate my frame.
Question:
1. What would be a good working process? (drawing>weldments>simulation?)
I have tried to look for tutorials and other things regarding this problem but most of weldment tutorials focus on adding structual members from the sketch and then stop. I have a hard time finding a tutorial or directions of how to actually "connect" all the structure member together so i can do some analyses with the complete frame. A sample of what kind of frames im doing is in the figure below:
Thanks in advanced
Hello Andrew,
Welcome to the forum. I'm afraid I don't know anything about simulation, but I wanted to let you know you might have a better chance of getting help with your question if you move the discussion to the Simulation section of the forum. No need to start a new one, just click on "Move discussion" in the Actions box at top right.
Also, since you're a new forum member, you might want to check this discussion: https://forum.solidworks.com/thread/39793. It has some information to help you get the most out of it.
