1 Reply Latest reply on Oct 10, 2013 12:24 AM by Deepak Gupta
    Traverse the Note in Sheet Format?
    Yong Ning
      Sub llll3()
        Dim SwApp As SldWorks.SldWorks
        Set SwApp = Application.SldWorks
        Dim SwModel As ModelDoc2, SwDraw As DrawingDoc
        Set SwModel = SwApp.ActiveDoc
        Set SwDraw = SwModel
        Dim SwView As View, kk As Integer
        Dim SwNote As Note
        Set SwView = SwDraw.GetFirstView
        Do While Not SwView Is Nothing
           Debug.Print SwView.GetName2
           Set SwNote = SwView.GetFirstNote
           Do While Not SwNote Is Nothing
              Debug.Print kk, SwNote.GetName & "@" & SwView.Name
              kk = kk + 1
              Set SwNote = SwNote.GetNext
           Loop
           Set SwView = SwView.GetNextView
        Loop
      Result is
      0            DetailItem1@Sheet1
      1            DetailItem2@Sheet1
      2            DetailItem3@Sheet1
      3            DetailItem4@Sheet1
      4            DetailItem5@Sheet1
      5            DetailItem6@Sheet1
      Sub lllfff()
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
        Dim SwSelMgr As SelectionMgr, tmp, Str
        Set SwSelMgr = SwModel.SelectionManager()
        Str = "DetailItem16@Sheet1" → don't Select Note
        tmp = SwModel.Extension.SelectByID2(Str, "NOTE", 0, 0, 0, False, -1, Nothing, 0)
        Debug.Print tmp→ result is False
      'recodr Macro result is
        Str = "DetailItem50@Sheet Format1"
        tmp = SwDraw.Extension.SelectByID2(Str, "NOTE", 0, 0, 0, False, 0, Nothing, 0)
        Debug.Print tmp  → Result is True
      Help me,Traverse view in Sheet Format1→
              kk = kk + 1
           Loop
      How to SwView.Name  →       Str = "DetailItem50@Sheet1" (View name is Sheet1)
         → Str = "DetailItem50@Sheet Format1" (Viewname is Sheet Format1)
      Thanks.
