I have a problem with the solidworks 2013 task scheduler, and i cant use it for nothing. The problem is related do the Task working folder that is missing from the add-in.
I tried to insert one identical to the task scheduler in the Solidworks 2012 and program says that i need to resart it (when i'm trying to do a task, after changing the task folder), so i resart it and then the task folder disappears, again!. So i cant use Solidworks 2013 Task scheduler with sp4.0 like i used the Solidworks 2012.
Any solution for this problem!? I tried to reinstall Solidworks 2013 and have no sucess.
I added some pictures so i can help you to understand me.
Thank you
Best regards
Diogo Louro
Welcome to SolidWorks forums Diogo.
Make sure that you have write access to the task working folder you've specified.
You might also find this post helpful for your future reference.
