hole callouts in drawings
Question asked by Sarah Wells on Oct 8, 2013
Latest reply on Dec 11, 2013 by Anna Wood
When I use the Hole Wizard to create a tapped hole and then bring the model into the fabrication drawing. In the drawing you can choose to use the hole callout annotation command and it works perfectly with the countersunk and counter bored holes but it doesn't read the tapped hole. The annotation still comes through as the diameter of the hole and depth, not the tap size or anything. Is there a way to allow the tap annotation to be quickly added to the drawing without using that hole callout button? I shold add, it doesn't come through on the hole table either. Any and all suggestions are welcome! Thank you, Sarah
