4 Replies Latest reply on Oct 8, 2013 7:21 AM by Donovan Soohoo
    VBA Sort of Excel Spreadsheet
    Donovan Soohoo
      I am having trouble with a VBA macro that exports sketch points. I am able to send data from SW to Excel and save the file, but I'd like to sort a range "MyRangeString" within a sheet called "MySheet". Basically, I want to sort by column B then column C. I placed a code snipet below. The data does not sort. I can get the same code to work natively in Excel no problem. Thanks in advance for your help.
      MyRangeString = "B2:B" & (i + 1)
      MyXRangeString = "B2:B" & (i + 1)
      MyYRangeString = "C2:C" & (i + 1)
      With MySheet.Sort
           .SortFields.Clear
           .SortFields.Add Key:=MySheet.Range("B2:B12"), _
           SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
           .SortFields.Add Key:=MySheet.Range("C2:C12"), _
           .SetRange MySheet.Range("A1:C12")
           .Header = xlYes
           .MatchCase = False
           .Orientation = xlTopToBottom
           .SortMethod = xlPinYin
           .Apply
      End With
