We have a situation here that I am sure is not all that unique.
Part A, is a common part that is used in many applications, but it also used as the raw component part in which machining is applied.
Part A + B Machining = Part AB
Part A + C Machining = Part AC
Part A + D Machining = Part AD
and so on..............
So how does everyone implement this in Solidworks? I see a couple of different ways, but the biggest challenge is to due with updates on Part A.
Option 1
Save As Copy of Component A, and apply changes. Now have new part AB.
If for some reason Part A changes, I know have to update part AB,AC,AD,AE........... manually.
Option 2
Create an assembly with Part A, called Part AB. Apply machining to assembly (Cut Revolve & Cut Extrude).
Decent option. Shows well in WPDM and reflects what in the ERP.
Option 3
Import Part A into Part AB (not as an assembly). Apply features (cut....) to imported part.
Similar to Option 2, but less visable in WPDM. More difficult to manage and oritentate the part.
I much prefer option B. But I was curious what everone else does?
I would do it with configurations. I would model part A and do different configs for AB, AC, AD, etc.
