Hi, is there any way to use a macro to change the folders description (PLATE, SW-Thickness x SW-Width x SW-Lengthname) for a body name inside the folder.?
Hi Deepak, it’s good to hear from you, Yes that would be great if you can make a macro to use rename the cut list folders based on the description of the solid body, you may need to add some prefix at the end of the folder name since it may not let you use the same
name already entered for the solid body. But the main goal would be to the change the standard description property name for something more meaningful like the name of the body that is already there and use it on the bill of materials.
If I'm understanding correctly, you want to rename the folder based on the description of the body contained in the folder.
It can be done but this would rename all the folders under Cutlist even created by weldment feature. If that can work for you then I can make the macro for you to try/use.
