DKDaniel Kitts07/10/2013
I am trying to determine the deformation/displacement of a given point in my model. I've tried using the "Probe" tool to select a point on the deformed model (after simulation is run) and comparing that coordinate to the same point on the model before analysis. However, I do not think that it is giving me the correct displacment value since the location of the deformed point does not change with other load cases.
If I wanted to determine the x, y, and z displacement of a given point, line, plane, etc., after load cases and deformation is calculated, how would I go about doing that? I need to know deformation at specific locations, I am not interested in the maximum value for the entire model.
