2 Replies Latest reply on Oct 8, 2013 6:12 AM by Yong Ning
    Vertical Ordinate Dimensions → with API
    Yong Ning
      1. With a drawing or sketch active, click Vertical Ordinate Dimension on the Dimensions/Relations toolbar, or click Tools, Dimensions, Vertical Ordinate.
        • Re: Vertical Ordinate Dimensions → with API
          Deepak Gupta
          swModel.InsertVerticalOrdinate
              Yong Ning
              Thanks your tips
              swModel.InsertVerticalOrdinate → result is
              The code is
              ' C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\swx392\Macro1.swb - macro recorded on 10/03/13 by Administrator
              Dim swApp As Object
              Dim Part As Object
              Dim SelMgr As Object
              Dim boolstatus As Boolean
              Dim Feature As Object
              Set Part = swApp.ActiveDoc
              Set SelMgr = Part.SelectionManager
              Part.InsertVerticalOrdinate
              Part.ClearSelection2 True
              boolstatus = Part.ActivateView("工程视图3")
              boolstatus = Part.Extension.SelectByID2("Line17", "SKETCHSEGMENT", 0.1601071431138, 0.1349123990804, 0, False, 0, Nothing, 0)
              Set Annotation = Part.AddDimension2(0.140856, 0.135329, -7.45171E-16)
              boolstatus = Part.Extension.SelectByID2("Point30", "SKETCHPOINT", -0.08812260999259, -0.1020879148938, 0, False, 0, Nothing, 0)
              Set Annotation = Part.AddDimension2(0.161885, 0.14615, -7.45171E-16)
              boolstatus = Part.Extension.SelectByID2("Point35", "SKETCHPOINT", -0.07145594819719, -0.08197982673322, 0, False, 0, Nothing, 0)
              Set Annotation = Part.AddDimension2(0.165254, 0.15105, -7.45171E-16)
              boolstatus = Part.Extension.SelectByID2("Point36", "SKETCHPOINT", -0.05478928640178, -0.06493782135757, 0, False, 0, Nothing, 0)
              Set Annotation = Part.AddDimension2(0.168623, 0.154113, -7.45171E-16)
              boolstatus = Part.Extension.SelectByID2("Point37", "SKETCHPOINT", -0.03812262460637, -0.05204405868885, 0, False, 0, Nothing, 0)
              Set Annotation = Part.AddDimension2(0.171889, 0.15646, -7.45171E-16)
              boolstatus = Part.Extension.SelectByID2("Point38", "SKETCHPOINT", -0.02145596281096, -0.04345182913557, 0, False, 0, Nothing, 0)
              Set Annotation = Part.AddDimension2(0.175156, 0.1584, -7.45171E-16)
              boolstatus = Part.Extension.SelectByID2("Point39", "SKETCHPOINT", -0.004789301015546, -0.04033917396553, 0, False, 0, Nothing, 0)
              Set Annotation = Part.AddDimension2(0.178525, 0.159013, -7.45171E-16)
              Part.Save2 False
              boolstatus = Part.Extension.SelectByID2("图纸1", "SHEET", 0.2215858012411, 0.1787850418991, 0, False, 0, Nothing, 0)
              'Add Ordinate Dimension Example (VB)
              'This example shows how to add an ordinate dimension.
              ' Preconditions:
              '          1) Drawing document is open.
              '          2) Two horizontal parallel edges are selected.
              ' Postconditions: Ordinate dimension added.
              Option Explicit
              Public Enum swAddOrdinateDims_e
                  swOrdinate = 1
                  swVerticalOrdinate = 2
                  swHorizontalOrdinate = 3
              End Enum
              Public Enum swCreateOrdDimError_e
                  swCreateOrdDimErr_Undefined = -1            '  If encountered, report as SPR.
                  swCreateOrdDimErr_Success = 0
                  swCreateOrdDimErr_GenFailure = 1            '  MSG_SDIM_BAD_DIM
                  swCreateOrdDimErr_GenNoInternalDims = 2     '  MSG_NO_INTERNAL_DIMS_IN_DSKETCH
                  swCreateOrdDimErr_GenBadSel = 3             '  MSG_DIM_REF_NOCREATE
                  swCreateOrdDimErr_GenNeedModelLoaded = 4    '  MSG_CANNOT_DIM_GHOST_IN3D
                  swCreateOrdDimErr_GenSamePartOnly = 5       '  MSG_DIM_EDIT_PART
                  swCreateOrdDimErr_GenExtraSelection = 6     '  MSG_DIM_TOO_MANY_SELECT
                  swCreateOrdDimErr_OrdFailure = 7            '  MSG_BAD_ORDINATE_DIM0
                  swCreateOrdDimErr_OrdDupInGroup = 8         '  MSG_BAD_ORDINATE_DIM1
                  swCreateOrdDimErr_OrdBadDir = 9             '  MSG_BAD_ORDINATE_DIM2
              End Enum
                  Dim swApp                   As SldWorks.SldWorks
                  Dim swModel                 As SldWorks.ModelDoc
                  Dim swDraw                  As SldWorks.DrawingDoc
                  Dim nRetval                 As Long
                  Set swModel = swApp.ActiveDoc
                  Set swDraw = swModel
                  ' Horizontal ordinate ignores X placement
                  nRetval = swDraw.AddOrdinateDimension2(swHorizontalOrdinate, -0.1, 0.02, 0#)
              See attatch
