We recently upgraded to SolidWorks 2013 SP4 from SolidWorks 2012 SP5. Now when we try to insert components into an assembly the EPDM search the search defaults to custom (This fills *.SLDPRT;*.SLDASM;*.PRT;*.ASM into the file name space) which will not actually find existing parts. When you pull down to All files the file name space stays empty and the search works.
I need to either change the custom so that it works or change the default so it is not custom. My users assume that the part does not exist and make a new part which is a big problem.
Attached are screenshots of the issue. (I redacted my company’s personal info) Thanks in advance for any advice!
Cherise
