3 Replies Latest reply on Oct 8, 2013 4:06 AM by Vishal Pambhar
    How to get edge length thru API
    Vishal Pambhar
      ..Please help me..
      I would like get length of selected edge(Body edge.Refer Attached jpeg) using API...For that i have wrote some code but it giving me some error.Error code highlighted by red color..Please find the code below..
      Dim doc As SldWorks.ModelDoc2
      Dim part As SldWorks.PartDoc
      Dim feat As SldWorks.Feature
      Dim sketch As SldWorks.sketch
      Dim v As Variant
      Dim i As Long
      Dim sseg As SldWorks.SketchSegment
      Dim sline As SldWorks.SketchLine
      Dim sp As SldWorks.SketchPoint
      Dim ep As SldWorks.SketchPoint
      Dim s As String
      Dim boolstatus As Boolean
      Dim swApp     As SldWorks.SldWorks
      Dim swModel   As SldWorks.ModelDoc2
      Dim swSelMgr  As SldWorks.SelectionMgr
      Dim swSelObji  As Object
      Dim swSkLine    As SldWorks.SketchLine
      Dim bRet        As Boolean
      Dim nDisti     As Double
      Set swModel = swApp.ActiveDoc
          For i = 1 To 100
          Set swSelObji = swSelMgr.GetSelectedObject5(i)
          nDisti = swSelObji.GetLength
      Set exApp = CreateObject("Excel.Application")
      If Not exApp Is Nothing Then
        exApp.Visible = True
         Set exApp = GetObject(, "Excel.Application")
         Set Sheet = exApp.ActiveSheet
      Sheet.Cells(13, 4).Value = nDisti * 1000
          Sheet.Cells(13, 1).EntireRow.Resize(1).Insert
      Next i
        • Re: How to get edge length thru API
          Deepak Gupta
          You need to use swCurve.GetLength2 and not GetLength as this is for sketch length.
          Check this example: Get Length of Edge Example (VBA)
            Keith Rice
            You're getting an error because you aren't using the required arguments with ICurve::GetLength.
            Anyway, ICurve::GetLength is obsolete, like Deepak said. You should use ICurve::GetLength2 if you want the base curve and ICurve::GetLength3 if you want the trimmed curve. So you might try out each one and see which one gives you the result you need. See the API Help remarks for GetLength3 to learn more.
            Here's how to get the length of a selected edge using ICurve::GetLength3. The length is printed in the immediate window.
            Dim swEdge As SldWorks.Edge
            Dim swCurve As SldWorks.Curve
            Dim swCurveParams As SldWorks.CurveParamData
            Dim dblLength As Double
                For i = 1 To swSelMgr.GetSelectedObjectCount2(-1)
                    If swSelMgr.GetSelectedObjectType3(i, -1) = 1 Then
                        Set swEdge = swSelMgr.GetSelectedObject6(i, -1)
                        Set swCurve = swEdge.GetCurve
                        Set swCurveParams = swEdge.GetCurveParams3
                        dblLength = swCurve.GetLength3(swCurveParams.UMinValue, swCurveParams.UMaxValue)
                        dblLength = Round(dblLength, 4)
                        Debug.Print " Length = " & dblLength * 1000 & "mm"; g
                Next i
            Keith
            SolidWorks API Tutorials
