Currently I'm using a tabbed section to display different controls depending on a droplist. That works fine. I have the first tab as blank, so that there is nothing showing until an option is chosen. If I set values and save with a tab that has content showing, deselect and reselect the folder\file the first tab is selected. It only comes back if I activate the list for the controlling variable. Is there a way to have that tab stay showing?
I have created a hidden text control that uses the input formula alias to shorten one of the values in the controling drop list.
EPDM 2013
Well, I played around with it, and if I do not use the text control with the input it stays. It seems that the variable doesn't stay saved in the text control.
Does anyone know how to get have the value save using a input formula? I thought that it would work fine, but I guess not.
