Looking for some direction to achieve some workflow links. I have yet to use actual workflow links and apparently my understanding of how they work is flawed.
We have a current workflow established that handles the initial release of all of our drawings. What we want is to create another workflow to handle just the revision. This would also up the revision count at the beginning of the drafting process as well as minimize the number of approvals actually required. My understanding before was that I could link our "RELEASED" state directly to a workflow link, thus sending the files into the "new workflow", perform the necessary rev count and approval transitions, and then send it back to the same "RELEASED" state in the original workflow. Attempting to execute this, I no longer believe this to be how to perform the task.
Can anyone point me to towards the cleanest way to achieve this? I technically could build it into the original workflow and rename the transitions, but its already awfully complex and cumbersome. There are also some other CM related tasks we have discussed being able to achieve with workflow links.
I apologize for my noobness. I attempt to manage PDM in my "spare" time, so I'm learning as I go.
Thanks.
Why?
That is how workflow links work. You send it from one state in workflow A to a different state in Workflow B. If you want to then send it back to Workflow A you can. I do this with no problems. What specifically isn't working for you?
I use workflow links in two places:
sends the file to the 'Rejected' workflow:
The process is the same regardless of where in the process the drawing is rejected: the drawing originator must correct the problem that caused the rejection and resubmit it for approval by everyone again. So rather than duplicate the states in the main workflow, they are broken out into the Rejected workflow. There is a similar link to a Recalled workflow which is intended for use when the drawing originator notices a problem before or between approvals. They can recall the drawing as though it was never submitted for approval, make any changes and then resubmit.
Your description of your problem isn't very clear. Since EPDM is so flexible, you have to be very specific in describing your problem, becase everyone's setup is different.
Jim S.
