4 Replies Latest reply on Oct 4, 2013 10:45 AM by Tapani Sjoman
    How to get Custom Properties of suppressed components in an assembly using VBA?
    Kamaleswaran Arunachala
      I need some helpt on my below requirement.
      I’m looking to retrieve custom property value of suppressed components using VBA programming in an Assembly file and display them in the listbox of a dialogue form. Can anyone please help with some example code?
      I’m able to retrieve the values when the components are “unsuppressed” using the below syntax:
         Set swModel = swApp.ActiveDoc
         VatComp = swApp.ActiveDoc.GetComponents(True)
         For I = 0 To UBound(VatComp)
      Set swComp = VatComp(I)
      Set swCompDoc = swComp.GetModelDoc2
      FileName = swComp.Name
      Set swCPM = swCompDoc.Extension.CustomPropertyManager("")
      swCPM.Get4 "description", False, DescValOut, DescResolvedOut
      Prop = DescResolvedOut
      ListboxAllGroups.AddItem FileName & " - [" & Prop & "]"
         Next
      Thanks in advance.
      Kamalesh.
