2 Replies Latest reply on May 7, 2016 5:59 AM by Yong Ning
    don't Prompt box for Adddimension2
    Yong Ning
      use Adddimension2, Prompt box ,See Fig.
      Help me, don't Prompt box
      Sub ll()
        Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
        Dim SwSelMgr As SelectionMgr, tmp
        Set SwModel = Application.SldWorks.ActiveDoc
        Dim SwSeg As SketchSegment
        Set SwSelMgr = SwModel.SelectionManager
        Set SwSeg = SwSelMgr.GetSelectedObject5(1)
        SwSeg.Select True
        With SwModel
          '.AddDimension2 0.15, 0.2, 0
          .AddDimension 0.15, 0.2, 0
          .ClearSelection2 False
          '.EditUndo 0
        End With
        • Re: don't Prompt box for Adddimension2
          Artem Taturevych
              swApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swInputDimValOnCreate, False
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
            Yong Ning
            Thans Artem Taturevych , Thans yor tips
            the code is
            Sub lll()
                Dim SwApp As SldWorks.SldWorks, swModel As SldWorks.ModelDoc2, swSketch As SldWorks.Sketch
                Dim swSketchSeg As SldWorks.SketchSegment, swSelMgr As SldWorks.SelectionMgr
                Dim vSketchSeg As Variant, vSketchSegID As Variant
                Dim ii As Long, bRet As Boolean
                Dim SwDim As Dimension, SwDisp As DisplayDimension, SwAnn As Annotation
                Set SwApp = Application.SldWorks
                SwApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swInputDimValOnCreate, False
                Set swModel = SwApp.ActiveDoc
                Set swSketch = swModel.GetActiveSketch2
                vSketchSeg = swSketch.GetSketchSegments
                For ii = 0 To UBound(vSketchSeg)
                    Set swSketchSeg = vSketchSeg(i)
                    vSketchSegID = swSketchSeg.GetID
                    Debug.Print "    SketchSegID(" & ii & ") = [" & vSketchSegID(0) & ", " & vSketchSegID(1) & "]"
                    Debug.Print "      Type       = " & swSketchSeg.GetType
                    Debug.Print "      Length     = " & swSketchSeg.GetLength
                    swSketchSeg.Select True
                    Set SwDisp = swModel.AddDimension2(0.15, 0.2, 0)
                    Set SwDim = SwDisp.GetDimension
                    Debug.Print SwDim.FullName, SwDim.SystemValue, SwDim.Value
                Next
                SwApp.SetUserPreferenceToggle swUserPreferenceToggle_e.swInputDimValOnCreate, True
            Private Sub ll()
               Dim Xls As Excel.Application, Sht As Worksheet, Rng As Range, EquationRng As Range
                   Set Xls = GetObject(, "Excel.Application")
                   Set Sht = Xls.Worksheets("JB4715")
                   Set Rng = Xls.Selection
                   Set EquationRng = Sht.Range("A:AZ").Find("CutPlateEquationRng").CurrentRegion
                   ''Debug.Print EquationRng.Address
               Dim x1(2), y1(2), x2(2), y2(2), DimArr: DimArr = Array("L", "W", "THK")
                   x1(0) = 0:    x1(1) = 0.1: x1(2) = 0.1
                   y1(1) = 0:    y1(1) = 0:    y1(2) = 0.05
                   x2(0) = 0.1: x2(1) = 0.1: x2(2) = 0.1 - 0.01
                   y2(0) = 0:    y2(1) = 0.05: y2(2) = 0.05
                   Set SwModel = SwApp.ActiveDoc
               Dim SwSelMgr As SelectionMgr, Tmp, ii, jj
                   'Tmp = SwModel.Extension.SelectByID2("Top Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
               Dim SwSketch As Sketch, SwSketchSeg As SketchSegment, SwAnn As Annotation
               Dim SwFeat As Feature, SwDim As Dimension, SwDispDim As DisplayDimension
                   SwModel.InsertSketch2 True
                   For ii = 0 To 2
                       Set SwSketchSeg = SwModel.CreateLine2(x1(ii), y1(ii), 0, x2(ii), y2(ii), 0)
                       SwSketchSeg.Select True
                       Set SwDispDim = SwModel.AddDimension2(x1(ii), y1(ii), 0)
                       Set SwDim = SwDispDim.GetDimension
                       SwDim.Name = DimArr(ii)
                       Debug.Print SwDim.Name
                   Next ii
                   Set SwSketch = SwSketchSeg.GetSketch
                   Set SwFeat = SwSketch
                   SwFeat.Name = "PlateSize"
               Dim SwEqnMgr As EquationMgr
                   Set SwEqnMgr = SwModel.GetEquationMgr
                   For ii = 2 To EquationRng.Rows.Count
                       SwEqnMgr.Add ii - 2, EquationRng(ii)
                   Next ii
