1 Reply Latest reply on Sep 28, 2013 11:19 AM by Yong Ning
    how to autodimension all sketches in Sheet metal
    Yong Ning
      Hope, with API, drawing dimension.
      Use API help example → don't drawing dimension.
      Autodimension All Sketches Example (VB)
      This example shows how to autodimension all sketches in a part.
        • Re: how to autodimension all sketches in Sheet metal
          Yong Ning
          API help
          the code is
          ' Preconditions:
          '       (1) Part is open.
          '       (2) Part contains at least one sketch.
          '       (3) Sketch contains some sketch segments or geometry.
          ' Postconditions: If successful, then all sketches have dimensions added to them.
          ' Notes: Return code from Sketch::AutoDimension2 is output to the
          '        debug window. Examine this window if the call fails.
          Option Explicit
          Public Enum swConstrainedStatus_e
              swUnknownConstraint = 1
              swUnderConstrained = 2
              swFullyConstrained = 3
              swOverConstrained = 4
              swNoSolution = 5
              swInvalidSolution = 6
              swAutosolveOff = 7
          End Enum
          Public Enum swSketchSegments_e
              swSketchLINE = 0
              swSketchARC = 1
              swSketchELLIPSE = 2
              swSketchSPLINE = 3
              swSketchTEXT = 4
              swSketchPARABOLA = 5
          End Enum
          Public Enum swAutodimEntities_e
              swAutodimEntitiesAll = 1
              swAutodimEntitiesSelected = 2
          End Enum
          Public Enum swAutodimMark_e
              swAutodimMarkEntities = &H1
              swAutodimMarkHorizontalDatum = &H2
              swAutodimMarkVerticalDatum = &H4
          End Enum
          Public Enum swAutodimScheme_e
              swAutodimSchemeBaseline = 1
              swAutodimSchemeOrdinate = 2
              swAutodimSchemeChain = 3
              swAutodimSchemeCenterline = 4
          End Enum
          Public Enum swAutodimHorizontalPlacement_e
              swAutodimHorizontalPlacementBelow = -1
              swAutodimHorizontalPlacementAbove = 1
          End Enum
          Public Enum swAutodimVerticalPlacement_e
              swAutodimVerticalPlacementLeft = -1
              swAutodimVerticalPlacementRight = 1
          End Enum
          Public Enum swAutodimStatus_e
              swAutodimStatusSuccess = 0
              swAutodimStatusBadOptionValue = 1
              swAutodimStatusNoActiveDoc = 2
              swAutodimStatusDocTypeNotSupported = 3
              swAutodimStatusNoActiveSketch = 4
              swAutodimStatus3DSketchNotSupported = 5
              swAutodimStatusSketchIsEmpty = 6
              swAutodimStatusSketchIsOverDefined = 7
              swAutodimStatusNoEntities = 8
              swAutodimStatusEntitiesNotValid = 9
              swAutodimStatusCenterlineNotAllowed = 10
              swAutodimStatusDatumNotSupplied = 11
              swAutodimStatusDatumNotUnique = 12
              swAutodimStatusDatumNotValidType = 13
              swAutodimStatusDatumLineNotCenterline = 14
              swAutodimStatusDatumLineNotVertical = 15
              swAutodimStatusDatumLineNotHorizontal = 16
              swAutodimStatusAlgorithmFailed = 17
          End Enum
          Public Enum swRebuildOptions_e
              swRebuildAll = &H1
              swForceRebuildAll = &H2
              swUpdateMates = &H4
              swCurrentSheetDisp = &H8
              swUpdateDirtyOnly = &H10
          End Enum
          Const swTnProfileFeature        As String = "ProfileFeature"
          Const nTolerance                As Double = 0.00000001
          Sub FindAllUnderConstrainedSketches _
          ( _
              swApp As SldWorks.SldWorks, _
              swModel As SldWorks.ModelDoc2, _
              sSketchNameArr() As String _
              Dim swPart                          As SldWorks.PartDoc
              Dim swFeat                          As SldWorks.Feature
              Dim swSketch                        As SldWorks.Sketch
              Dim bRet                            As Boolean
              Set swPart = swModel
              Set swFeat = swPart.FirstFeature
              Do While Not swFeat Is Nothing
                  If swTnProfileFeature = swFeat.GetTypeName Then
                      Set swSketch = swFeat.GetSpecificFeature2
                      If swUnderConstrained = swSketch.GetConstrainedStatus Then
                          sSketchNameArr(UBound(sSketchNameArr)) = swFeat.Name
                          ReDim Preserve sSketchNameArr(UBound(sSketchNameArr) + 1)
                  Set swFeat = swFeat.GetNextFeature
              Loop
              ' Remove last empty sketch name
              ReDim Preserve sSketchNameArr(UBound(sSketchNameArr) - 1)
          Function GetAllSketchLines _
          ( _
              swSketch As SldWorks.Sketch _
          ) As Variant
              Dim vSketchSegArr                   As Variant
              Dim vSketchSeg                      As Variant
              Dim swSketchSeg                     As SldWorks.SketchSegment
              Dim swSketchCurrLine                As SldWorks.SketchLine
              Dim swSketchLineArr()               As SldWorks.SketchLine
              ReDim swSketchLineArr(0)
              vSketchSegArr = swSketch.GetSketchSegments
              If Not IsEmpty(vSketchSegArr) Then
                  For Each vSketchSeg In vSketchSegArr
                      Set swSketchSeg = vSketchSeg
                      If swSketchLINE = swSketchSeg.GetType Then
                          Set swSketchCurrLine = swSketchSeg
                          Set swSketchLineArr(UBound(swSketchLineArr)) = swSketchCurrLine
                          ReDim Preserve swSketchLineArr(UBound(swSketchLineArr) + 1)
                  Next
              If 0 = UBound(swSketchLineArr) Then
                  ' No straight lines in this sketch
                  GetAllSketchLines = Empty
                  Exit Function
              ' Remove last empty sketch line
              ReDim Preserve swSketchLineArr(UBound(swSketchLineArr) - 1)
              GetAllSketchLines = swSketchLineArr
          End Function
          Function GetSketchPoint _
          ( _
              swSketch As SldWorks.Sketch, _
              swSketchPt As SldWorks.SketchPoint _
          ) As Boolean
              Dim vSketchPtArr                    As Variant
              vSketchPtArr = swSketch.GetSketchPoints
              If Not IsEmpty(vSketchPtArr) Then
                  ' Use first point
                  Set swSketchPt = vSketchPtArr(0)
                  GetSketchPoint = True
                  Exit Function
              GetSketchPoint = False
          End Function
          Function FindVerticalOrigin _
          ( _
              swSketchSegVert As SldWorks.SketchSegment, _
              swSketchPtVert As SldWorks.SketchPoint _
          ) As Boolean
              Dim vSketchLineArr                  As Variant
              Dim vSketchLine                     As Variant
              Dim swStartPt                       As SldWorks.SketchPoint
              Dim swEndPt                         As SldWorks.SketchPoint
              ' Try to get first vertical line
              vSketchLineArr = GetAllSketchLines(swApp, swModel, swSketch)
              If Not IsEmpty(vSketchLineArr) Then
                  For Each vSketchLine In vSketchLineArr
                      Set swSketchCurrLine = vSketchLine
                      Set swStartPt = swSketchCurrLine.GetStartPoint2
                      Set swEndPt = swSketchCurrLine.GetEndPoint2
                      If Abs(swStartPt.X - swEndPt.X) < nTolerance Then
                          Set swSketchSegVert = swSketchCurrLine
                          FindVerticalOrigin = True
                          Exit Function
                  Next
              ' Try to get the first point
              FindVerticalOrigin = GetSketchPoint(swApp, swModel, swSketch, swSketchPtVert)
          End Function
          Function FindHorizontalOrigin _
          ( _
              swSketchSegHoriz As SldWorks.SketchSegment, _
              swSketchPtHoriz As SldWorks.SketchPoint _
          ) As Boolean
              ' Try to get first horizontal line
                      If Abs(swStartPt.Y - swEndPt.Y) < nTolerance Then
                          Set swSketchSegHoriz = swSketchCurrLine
                          FindHorizontalOrigin = True
                          Exit Function
                  Next
              FindHorizontalOrigin = GetSketchPoint(swApp, swModel, swSketch, swSketchPtHoriz)
          End Function
          Function AutoDimensionSketch _
          ( _
          ) As Long
              Dim swSketchSegHoriz                As SldWorks.SketchSegment
              Dim swSketchPtHoriz                 As SldWorks.SketchPoint
              Dim swSketchSegVert                 As SldWorks.SketchSegment
              Dim swSketchPtVert                  As SldWorks.SketchPoint
              Dim bRet                            As Boolean
              If False = FindHorizontalOrigin(swApp, swModel, swSketch, swSketchSegHoriz, swSketchPtHoriz) Then
                  AutoDimensionSketch = swAutodimStatusDatumLineNotHorizontal
                  Exit Function
              If False = FindVerticalOrigin(swApp, swModel, swSketch, swSketchSegVert, swSketchPtVert) Then
                  AutoDimensionSketch = swAutodimStatusDatumLineNotVertical
                  Exit Function
              Set swFeat = swSketch
              bRet = swFeat.Select2(False, 0)
              Debug.Assert bRet
              ' Editing sketch clears selections
              swModel.EditSketch
              ' Reselect sketch segments for autodimensioning
              If Not swSketchSegVert Is Nothing Then
                  ' Vertical line is for horizontal datum
                  bRet = swSketchSegVert.Select4(True, Nothing)
              ElseIf Not swSketchPtHoriz Is Nothing Then
                       bRet = swSketchPtHoriz.Select4(True, Nothing)
              ElseIf Not swSketchPtVert Is Nothing Then
                      ' Use any sketch point for horizontal datum
                       bRet = swSketchPtVert.Select4(True, Nothing)
              Debug.Assert bRet
              If Not swSketchSegHoriz Is Nothing Then
                  ' Horizontal line is for vertical datum
                  bRet = swSketchSegHoriz.Select4(True, Nothing)
                      ' Use any sketch point for vertical datum
              Debug.Assert bRet
              ' No straight lines, probably contains circles,
              ' so use sketch points for datums
              If IsEmpty(GetAllSketchLines(swApp, swModel, swSketch)) Then
                      bRet = swSketchPtHoriz.Select4(False, Nothing)
                      bRet = swSketchPtVert.Select4(False, Nothing)
              Debug.Assert bRet
              AutoDimensionSketch = swSketch.AutoDimension2( _
                                      swAutodimEntitiesAll, _
                                      swAutodimSchemeBaseline, _
                                      swAutodimHorizontalPlacementBelow, _
                                      swAutodimVerticalPlacementLeft)
              ' Redraw so dimensions are displayed immediately
              swModel.GraphicsRedraw2
              ' Exit sketch edit
              ' Leave rebuild to later
              swModel.InsertSketch2 False
          End Function
              Dim swApp                           As SldWorks.SldWorks
              Dim swModel                         As SldWorks.ModelDoc2
              Dim sSketchNameArr()                As String
              Dim sSketchName                     As Variant
              Dim nRetVal                         As Long
              Dim i                               As Long
              Dim bRet                            As Boolean
              Set swModel = swApp.ActiveDoc
              Debug.Print "File = " & swModel.GetPathName
              ReDim sSketchNameArr(0)
              FindAllUnderConstrainedSketches swApp, swModel, sSketchNameArr
              For Each sSketchName In sSketchNameArr
                  Set swFeat = swPart.FeatureByName(sSketchName)
                  nRetVal = AutoDimensionSketch(swApp, swModel, swSketch)
                  Debug.Print "  " & sSketchName & " = " & nRetVal
              Next
              ' Rebuild after modifying sketches
              bRet = swModel.EditRebuild3
              Debug.Assert bRet
          'Autodimension a Sketch Example (VB)
          'This example shows how to autodimension a sketch.
          ' Preconditions:
          '       (1) Part or assembly is open.
          '       (2) Sketch is being edited.
          '       (4) At least two sketch entities are selected.
          '       (5) First selected sketch entity is used for horizontal datum.
          '       (6) Second selected sketch entity is used for vertical datum.
          ' Postconditions: If successful, then dimensions are added to sketch.
          ' NOTES: Return code from Sketch::AutoDimension2 is output to
          ' debug window and you should examine the code in the case of failure.
              Dim swSelMgr                        As SldWorks.SelectionMgr
              Dim nRetVal                         As Long
              Dim i                               As Long
              Dim bRet                            As Boolean
              Set swSketch = swModel.GetActiveSketch2
              Debug.Print
              Set swSketchSegHoriz = swSelMgr.GetSelectedObject5(1)
              Set swSketchSegVert = swSelMgr.GetSelectedObject5(2)
              swModel.ClearSelection2 True
              ' Reselect sketch segments with correct marks
              ' for auto-dimensioning
              bRet = swSketchSegHoriz.Select3(True, swAutodimMarkHorizontalDatum, Nothing)
              bRet = swSketchSegVert.Select3(True, swAutodimMarkVerticalDatum, Nothing)
              nRetVal = swSketch.AutoDimension2( _
              Debug.Print "  AutoDim = " & nRetVal
