I am currently working with a fairly complex model with many variable fillets and I have to remove them in order to add draft onto the part. What are some methods to rmove these fillets without having to use FeatureWorks?
I've tried using the Delete and Patch option of several models and for some reason I haven't gotten it to work once. I don't know if it has to with the import being bad or anything of that sort.
Are you able to post the part for testing? Use the Use advanced editor link at the top RH corner of the reply box.
I knoe there are quite a few faces but these are the ones that i have to eliminate in order to add draft
Thanks Bobby. You are correct, there is something strange with this part's topology.
Anyhow, this is what I done so far (see attached).
Bobby,
Alin's right, the part is a little funny. Delete and patch would be my normal "go to" for this sort of thing and usually works quite well. Like adding fillets it's mostly a matter of working out the right order to delete them. No luck on this part.
I didn't look at Alin's solution but considering the number of fillets you need to remove, and the relative simplicity of the part, I found it easier to just make a new body using the import to get the geometry (convert entity for the most part). It leaves off all the fillets, but it's probably easier to add the ones you want to keep to the new body than remove all the others from the old one.
option 1) extrude, revolve, and/or sweep new corners over the radii.
option 2) delete face of fillet(s), extend remaining faces nad trim, knit, and make solid as appropriate.
option 3) ???
