Does anyone have any profiles created for these above shapes of steel for use in Turkey. I have projects these and am designing for fabrication using the above profiles.
Any help would be appreciated. I have looked in the DIN/ISO files from Solidworks but still need a few more profiles.
Hi Stephen
If you only need a few more profiles, you could just create them yourself once you know the profile dimensions for the beam you need.
What I normally do is open a profile that I already have and then do save as to save it as the new size, I then edit the sketch and modify the dimensions to the size I need, save the file and now I have my new size, it only takes about a minute to do each one, so even if you have 10 or 12 profies to do it should take you no more than 10 to 15 minutes. One thing to remember is to change the description field when you are doing the "save as" or you will still have the original beam size as the description when you come to putting a cut list in your drawing.
Paul
