9 Replies Latest reply on Dec 13, 2013 7:59 AM by Deepak Gupta
    GetConfigurationNames not working in SW2014 ?
    Checkcheck Master
      Anyone ?
      I use this command to retrieve the configuration names from a file.
      In SW2012/2013 there's no problem using it.
      Now in SW2014 it's not working anymore.
      Tried the example within the API help, same result, working in SW2012/2013, not working in SW2014.
      Is there something changed in SW2014 regarding this command ?
      Greetings !
      Option Explicit
           Dim swApp                   As SldWorks.SldWorks
           Dim swModel                 As SldWorks.ModelDoc2
           Dim vConfigName             As Variant
           Dim sConfigName             As String
           Dim swConfig                As SldWorks.Configuration
           Dim i                       As Long
           Dim bRet                    As Boolean
           Set swModel = swApp.ActiveDoc
            Set swConfig = swModel.GetActiveConfiguration
          Debug.Print "File = " & swModel.GetPathName
          Debug.Print "  Active Config = " & swConfig.Name
          Debug.Print ""
          vConfigName = swModel.GetConfigurationNames
          For i = 0 To UBound(vConfigName)
          sConfigName = vConfigName(i)
              Set swConfig = swModel.GetConfigurationByName(sConfigName)
               Debug.Print "  ConfigName(" + Str(i) + ") = " + sConfigName
               Debug.Print "    UseAlternateNameInBOM = " + Str(swConfig.UseAlternateNameInBOM)
               Debug.Print "    AlternateName         = " + swConfig.AlternateName
               Debug.Print "    Comment               = " + swConfig.Comment
               Debug.Print ""
          Next i
