17 Replies Latest reply on Oct 15, 2013 12:59 AM by Deepak Gupta
    How to insert macro into EPDM task?
    Emil Svallingson
      I have a macro working perfectly in SW but how do I insert it succesfully into a new EPDM task? This is the macro I am using:
      ' Save Assy As Part (Exterior Surfaces).swp ---------------------------06/16/12
      'Description: Macro to save assembly to save as part (Exterior Surfaces).
      '             Then saved part file is further saved as "STEP" file in the same location.
      'Precondition: Any active assembly with minimum one part.
      'Postcondition: Assembly is saved as part and part is saved as "STEP" file.
      ' Written by: Deepak Gupta (http://gupta9665.wordpress.com/)
      Dim swApp               As SldWorks.SldWorks
      Dim swModel             As SldWorks.ModelDoc2
      Dim swModelDocExt       As SldWorks.ModelDocExtension
      Dim FilePath            As String
      Dim sFilePath           As String
      Dim PathSize            As Long
      Dim PathNoExtension     As String
      Dim NewFilePath         As String
      Dim nErrors             As Long
      Dim nWarnings           As Long
      Set swModel = swApp.ActiveDoc
      Set swModelDocExt = swModel.Extension
      FilePath = swModel.GetPathName
      PathSize = Strings.Len(FilePath)
      PathNoExtension = Strings.Left(FilePath, PathSize - 6)
      NewFilePath = PathNoExtension & "SLDPRT"
      swApp.SetUserPreferenceIntegerValue swSaveAssemblyAsPartOptions, swSaveAsmAsPart_ExteriorFaces
      swModelDocExt.SaveAs NewFilePath, swSaveAsCurrentVersion, swSaveAsOptions_Silent, Nothing, nErrors, nWarnings
      swApp.CloseDoc swModel.GetTitle
      Set swModel = swApp.OpenDoc(NewFilePath, swDocPART)
      sFilePath = PathNoExtension & "STEP"
      swModel.SaveAs (sFilePath)
