5 Replies Latest reply on Oct 1, 2013 10:08 AM by Lenny Bucholz
    Mirroring a surfaced body and create a new part
    Cole Young
      Hi All,
      I have been working on a custom knife project and I used a series of boundry, planar and free form surfaces to create an organically shaped handle for the knife. I modeled the right hand side of the handle and would now like to mirror it to create the left hand side. I was not able to figure out how to mirror the RH handle at the component level. I was able to create a LH mirror at the assembly level but I am not happy with the results. If I go one route, I end up with a separate part that, when opened at the component level, is only a solid body, no features in the feature tree. If I go the other route, I get the features, but they translate back and forth between the original RH component, i.e. if I put bolt holes in the RH part, they show up in the LH mirrored part and if I put bolt holes in the LH mirrored part, they show up as a suppressed feature in the RH part.
      It seems to me that there should be an easy way to mirror the part and its features and save it as an independant component so that any changes made to the derived part would stay at that level.
      Is there a way to do this?
      Cole
        • Re: Mirroring a surfaced body and create a new part
          Lenny Bucholz
          Can you put up the part\s so we can talk the same as we type our answer.
          Mirrored parts have always worked this way, because since sketches cannot be mirrored inside the features of a mirrored part is the big issue.
          what alot of people do is make the whole handle then split the handle into the bodies needed then save those out as seperate parts, still no features but the part that makes them is where you do the edits, forget the term used for this, Industrial Designers use this all the time to get the main shape then add the details to the individual parts.
            Jerry Steiger
            Cole,
            At the part level, you probably need to mirror the body, rather than the features. If the knife handle will be assembled from the two parts, then you don't want to merge the two bodies when you dor the mirror. If the knife handle is molded around the tang, then you would want to merge the two bodies.
            The term Lenny was trying to remember was "master modeling", where you build a number of parts in a master model and then split them out into separate parts at some point.
            Jerry S.
                Cole Young
                Jerry,
                That makes sense and I can see the usefulness of doing it this way. What would be the preferred way to do it if I wanted to make, say, a right handed knife where each side of the handle was different. My first line of thought is to have the handle half mirrored with features and then edit the features to create the asymmetry. However, I have a feeling that you are going to tell me to again model the whole thing as one and then split.
                Cole
                    Lenny Bucholz
                    Cole,
                    Sorry I haven't done anything or replied, 25th anniversary, took wife to San Diego.
                    But to answer your last question, your master model (thanx Jerry, had a brain Fart) controls all your different versions.
                    one trick is mirror the shape early on, meaning if the shape at that point is in every version, them mirror, then ad the features to the new parts that only belong to that part, then only use the master to tweek the main shape and it probigates to all the others versions.
                    I do beleave there are some new ways in SW 2014, will see them on the 16th at the VAR rollout here in Phoenix, that may change this way of modeling.
                    you can also use configurations to make one part have many different looks to use for the handles or using multiple bodys in a part file to acheave the same results.
