5 Replies Latest reply on Dec 29, 2015 9:37 AM by Yong Ning
    WizardHoleFeatureData2 API problem
    Vinicius Pontes
      I'm trying to write a function which will change the "Size" of a "Tapped hole" hole wizard type.
      My HoleWizard feature has the hole in 3 positions, like the picture below. The problem is that only one of them is changed correctly. The oders show a wrong cosmetc, which is reflected in the drawing.
      I'm changing from M16 to M30, for example. The inner diameter is updated correctly, but the outer don't.
      Does anybody know why it's happening?
      I've notice that after the function completes its job, if I edit the feature and finishe edition without changing anything, the cosmetics is updated.
      Thanks for any help,
      Vinicius
      C++ code below:
      bool ChangeHoleWizardSize(IModelDoc2 *pModel, LPCTSTR featureName, LPCTSTR value)
                HRESULT hr = S_OK;
                VARIANT_BOOL ok = VARIANT_FALSE;
                IModelDocExtensionPtr ptrModelDocExt = NULL;
                pModel->get_Extension(&ptrModelDocExt);
                struct IDispatch *pDispatch = NULL;
                hr = pModel->get_SelectionManager(&pDispatch);
                ISelectionMgrPtr ptrSelMgr = NULL;
                pDispatch->QueryInterface(__uuidof(ISelectionMgr), reinterpret_cast<void**>(&ptrSelMgr));
                pDispatch->Release();
                ICalloutPtr ptrCallout = NULL;
                hr = ptrModelDocExt->SelectByID2(_bstr_t(featureName), _bstr_t("BODYFEATURE"), 0, 0, 0, VARIANT_FALSE, 0, ptrCallout, 0, &ok);
                if ( ok == VARIANT_FALSE )
                          return false;
                hr = ptrSelMgr->GetSelectedObject5(1, &pDispatch);
                IFeaturePtr ptrFeat = NULL;
                pDispatch->QueryInterface(__uuidof(IFeature), reinterpret_cast<void**>(&ptrFeat));
                IWizardHoleFeatureData2Ptr ptrHoleWiz = NULL;
                ptrFeat->GetDefinition(&pDispatch);
                pDispatch->QueryInterface(__uuidof(IWizardHoleFeatureData2), reinterpret_cast<void**>(&ptrHoleWiz));
                long nStandard = swStandardDIN;
                long nFastnerType = swStandardDINTappedHole;
                hr = ptrHoleWiz->get_Standard2(&nStandard);
                hr = ptrHoleWiz->get_FastenerType2(&nFastnerType);
                hr = ptrHoleWiz->AccessSelections(pModel, NULL, &ok);
                hr = ptrHoleWiz->ChangeStandard(nStandard, nFastnerType, _bstr_t(value), &ok);
                ptrHoleWiz->put_HoleFit(swScrewClearanceNormal);
                ptrFeat->IModifyDefinition2(ptrHoleWiz, pModel, NULL, &ok);
                ptrSelMgr.Release();
                ptrHoleWiz.Release();
                ptrFeat.Release();
                return ( ok != VARIANT_FALSE )?true:false;
        • Re: WizardHoleFeatureData2 API problem
          Vinicius Pontes
          I found out that there is nothing wrong with this function. There is a problem in the API which changes only the first hole cosmetics. To solve this problem I've linked the diameter's dimension of the holes up to the second with the dimension of the first hole:
          This is the first hole:
          This is the second hole:
          I've made the second hole's diameter equals to the first. Doing this, everything works well. You have to do this for every hole up to the second.
          Note: This is only needed when changing the Hole Wizard through API.
          Hope it helps,
          Vinicius Pontes
          For those how are interested, this is a VB version of this function:
          Dim Part As ModelDoc2
              Set Part = swApp.ActiveDoc
              Dim myModelView As Object
              Set myModelView = Part.ActiveView
              myModelView.FrameState = swWindowState_e.swWindowMaximized
              Part.Extension.SelectByID2 "M18x1.5 Tapped Hole2", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0
              Dim selMgr As SelectionMgr
              Set selMgr = Part.SelectionManager
              Dim feature As feature
              Set feature = selMgr.GetSelectedObject5(1)
              Dim holewiz As IWizardHoleFeatureData2
              Set holewiz = feature.GetDefinition
              Dim std As Long
              std = holewiz.Standard2
              Dim fst As Long
              fst = holewiz.FastenerType2
              Dim tpe As Long
              tpe = holewiz.TapType
              Dim sze As String
              sze = holewiz.FastenerSize
              Dim result As Boolean
              holewiz.AccessSelections Part, Nothing
              result = holewiz.ChangeStandard(std, fst, "M30x2.0")
              result = feature.ModifyDefinition(holewiz, Part, Nothing)
              Part.EditRebuild3
              Part.ForceRebuild3 False
              Matt Martens
              I am trying to use the method you described above for some hole wizard changes myself. I was wondering if when running your code the tap drill diameter is changing. I cannot get it to change when I run it here. The cosmetic threads change diameter and feature name updates, but i cannot get the tap drill diameter to update.
              Any suggestions?
                Yong Ning
                Private Sub ll2()
                   Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2
                      Set SwApp = Application.SldWorks
                      Set SwModel = SwApp.ActiveDoc
                   Dim SwSelMgr As SelectionMgr
                      Set SwSelMgr = SwModel.SelectionManager
                   Dim Feature As SldWorks.Feature
                   Dim SwFeatData As SldWorks.WizardHoleFeatureData2
                       ' Here Write code for selecting the feature
                       Set Feature = SwSelMgr.GetSelectedObject5(1)
                       Set SwFeatData = Feature.GetDefinition
                       With SwFeatData
                          tmp = .ChangeStandard(swStandardISO, swStandardISOTappedHole, "M20")
                       End With
                       tmp = Feature.ModifyDefinition(SwFeatData, SwModel, Nothing)
                       Stop
