Task - PDF Conversion Advanced Script: Completes successfully but E-PDM thinks it failed
Question asked by R. Seegmiller on Sep 26, 2013
Latest reply on Sep 27, 2013 by R. Seegmiller
I am having trouble with a number of PDF conversion scripts that are reported to fail, however the output files are created correctly.
I have reduced the script I am having trouble with to the following:
' Convert Task VB Script
' Created by Richard Seegmiller, modeled after SW default Advanced Script
' To diagnose why Advanced Scripts are failing though they exit clean
' Created: 25 September 2013
Debug.Assert False
    On Error GoTo Fail:
    docFileName = "<Filepath>"
    Exit Sub
Fail:
After stepping through the debugger, the above script completes successfully.  According to the results in the Task List, the task failed.  There is no error log generated.  The email that is sent also does not give any clues as to why the task failed.  Sanitized email as follows:
SolidWorks Enterprise PDM notification
________________________________________
System was unable to auto create the MS Word Specification PDF.
The task was initiated by JDoe on JOHNPC running as Admin
File Name    Version    View    Get Version    Properties    History    Folder
MyPart.SLDDRW
1    View
Get Version
Properties
History
\Some\Folder\Path\
Suggestions anyone?
